Up to 20% off select tools
HP ProBook 640 G1 RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
97
All Time:
679
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing the RAM (Random Access Memory) for your HP ProBook 640 G1 laptop. If you notice your computer running slowly, or you notice it has a hard time running multiple tasks at once, it may be time to upgrade your RAM.
    1. HP ProBook 640 G1 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside down to show the battery lock slider.
      • It is a black slider near the top, with a battery logo to the left and a lock sign to the right.
      Ask FixBot
    2. HP ProBook 640 G1 RAM Replacement: step 2, image 1 of 1
      • Slide the battery slider all the way to the left, towards the battery symbol.
      • You may also need to slide the other slider to the right of the battery slider, as shown in the picture.
      Ask FixBot
    3. HP ProBook 640 G1 RAM Replacement: step 3, image 1 of 1
      • Remove the battery by sliding it away from the laptop while holding the battery locker.
      • The battery should slide out with ease.
      Ask FixBot
    1. HP ProBook 640 G1 RAM Replacement, Back Panel: step 4, image 1 of 2 HP ProBook 640 G1 RAM Replacement, Back Panel: step 4, image 2 of 2
      • Slide down and pull up on the cover to remove it.
      Ask FixBot
    1. HP ProBook 640 G1 RAM Replacement, Midframe: step 5, image 1 of 3 HP ProBook 640 G1 RAM Replacement, Midframe: step 5, image 2 of 3 HP ProBook 640 G1 RAM Replacement, Midframe: step 5, image 3 of 3
      • Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
      • Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
      • Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
      • Some of the screws are held in place by springs and cannot be fully removed, but can still be loosened.
      Ask FixBot
    2. HP ProBook 640 G1 RAM Replacement: step 6, image 1 of 2 HP ProBook 640 G1 RAM Replacement: step 6, image 2 of 2
      • Remove the disk drive by gently pulling it out.
      • Remove the two 3 mm screws using a Phillips #1 screwdriver.
      • Only one screw is visible in the photo the second screw is located directly above it.
      Ask FixBot
    3. HP ProBook 640 G1 RAM Replacement: step 7, image 1 of 2 HP ProBook 640 G1 RAM Replacement: step 7, image 2 of 2
      • Gently pull up on the midframe, gripping it from the inside.
      • This may take a small amount of force. If it feels stuck, check for missed screws. Go back to the previous steps and make sure you have removed all necessary screws.
      Ask FixBot
    1. HP ProBook 640 G1 RAM Replacement, RAM: step 8, image 1 of 3 HP ProBook 640 G1 RAM Replacement, RAM: step 8, image 2 of 3 HP ProBook 640 G1 RAM Replacement, RAM: step 8, image 3 of 3
      • Gently push the clasps securing the RAM outwards and down to free the RAM.
      • Gently grab the sides of the RAM stick and remove it from its socket by pulling it to the right.
      • Repeat this process for the second RAM stick located underneath the first.
      Ask FixBot
Author
with
Carter Wilcomb
199 Reputation
2 Guides authored
UMass Dartmouth, Team 4-2, Biswokarma Fall 2025 Member of UMass Dartmouth, Team 4-2, Biswokarma Fall 2025
UMASSD-BISWOKARMA-F25S4G2
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 97
All Time: 679
