Up to 20% off select tools
HP ProBook 4740s RAM Replacement
View statistics:
Past 24 Hours:
10
Past 7 Days:
31
Past 30 Days:
107
All Time:
865
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 seconds - 2 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
    1. HP ProBook 4740s RAM Replacement, Removing the battery and backplate: step 1, image 1 of 2 HP ProBook 4740s RAM Replacement, Removing the battery and backplate: step 1, image 2 of 2
      • Hold in both "levers" so the battery pops out of place. Do this again to remove the backplate.
      Ask FixBot
    2. HP ProBook 4740s RAM Replacement, Removing the old RAM: step 2, image 1 of 3 HP ProBook 4740s RAM Replacement, Removing the old RAM: step 2, image 2 of 3 HP ProBook 4740s RAM Replacement, Removing the old RAM: step 2, image 3 of 3
      • Press on both clasps outwards so that the stick of RAM lifts up out of place. Then, simply remove it.
      Ask FixBot
    3. HP ProBook 4740s RAM Replacement, Installing the new RAM: step 3, image 1 of 1
      • Take a replacemnt stick of RAM, place it in the slot and push down until it clicks into place.
      Ask FixBot
    4. HP ProBook 4740s RAM Replacement, Installing the Backplate and battery: step 4, image 1 of 2 HP ProBook 4740s RAM Replacement, Installing the Backplate and battery: step 4, image 2 of 2
      • Simply slide the backplate into place, from the bottom end to the top end of the laptop. Then, take the battery and push until it clicks into place.
      Ask FixBot
Easy replacemnt of a faulty RAM stick. Same instructions apply when upgrading.
Author
with
Mevaa
109 Reputation
1 Guide authored
1 Guide Comment
the easiest SSD swap of my life
Arc-En-Miel - Reply Share
Past 24 Hours: 10
Past 7 Days: 31
Past 30 Days: 107
All Time: 865
