HP ProBook 455 G7 Lower Case Replacement
    1. HP ProBook 455 G7 Lower Case Replacement, Lower Case: step 1, image 1 of 1
      • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
      • Flip the laptop over so the lower case is facing up.
      • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
      Ask FixBot
    2. HP ProBook 455 G7 Lower Case Replacement: step 2, image 1 of 3 HP ProBook 455 G7 Lower Case Replacement: step 2, image 2 of 3 HP ProBook 455 G7 Lower Case Replacement: step 2, image 3 of 3
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Lift and remove the lower case.
      Ask FixBot
Connor Bassolino
26,156 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 67
All Time: 206
