HP ProBook 455 G7 Battery Replacement
    1. HP ProBook 455 G7 Battery Replacement, Lower Case: step 1, image 1 of 1
      • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
      • Flip the laptop over so the lower case is facing up.
      • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
      Ask FixBot
    2. HP ProBook 455 G7 Battery Replacement: step 2, image 1 of 3 HP ProBook 455 G7 Battery Replacement: step 2, image 2 of 3 HP ProBook 455 G7 Battery Replacement: step 2, image 3 of 3
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Lift and remove the lower case.
      Ask FixBot
    1. HP ProBook 455 G7 Battery Replacement, Battery: step 3, image 1 of 3 HP ProBook 455 G7 Battery Replacement, Battery: step 3, image 2 of 3 HP ProBook 455 G7 Battery Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
      • Carefully lift the battery and remove it from the laptop.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Andiany Reynoso
259 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 109
All Time: 390
