HP ProBook 455 G1 Hard Drive Replacement
    1. HP ProBook 455 G1 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
      • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
      Ask FixBot
    2. HP ProBook 455 G1 Hard Drive Replacement: step 2, image 1 of 1
      • Slide the two battery release latches towards the center of the laptop to release the battery.
      Ask FixBot
    3. HP ProBook 455 G1 Hard Drive Replacement: step 3, image 1 of 2 HP ProBook 455 G1 Hard Drive Replacement: step 3, image 2 of 2
      • Tilt the battery upward.
      • Remove it from the laptop.
      Ask FixBot
    1. HP ProBook 455 G1 Hard Drive Replacement, Service Panel: step 4, image 1 of 1
      • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
      Ask FixBot
    2. HP ProBook 455 G1 Hard Drive Replacement: step 5, image 1 of 2 HP ProBook 455 G1 Hard Drive Replacement: step 5, image 2 of 2
      • Slide the service panel toward you using your thumbs.
      • Lift it to remove the panel and reveal inner components of the computer.
      Ask FixBot
    1. HP ProBook 455 G1 Hard Drive Replacement, Hard Drive: step 6, image 1 of 2 HP ProBook 455 G1 Hard Drive Replacement, Hard Drive: step 6, image 2 of 2
      • Using a Phillips #0 Screwdriver, remove the four Phillips 3 mm screws that secure the hard drive into the computer.
      Ask FixBot
    2. HP ProBook 455 G1 Hard Drive Replacement: step 7, image 1 of 1
      • Pull the hard drive cover tab to the left in order to disconnect the hard drive from the computer.
      Ask FixBot
    3. HP ProBook 455 G1 Hard Drive Replacement: step 8, image 1 of 1
      • Finally, using the same tab, lift the hard drive out of the hard drive port.
      Ask FixBot
7 other people completed this guide.
Bailey Brammer
355 Reputation
1 Guide authored
Baylor, Team S5-G1, Williams Spring 2018 Member of Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 83
All Time: 8,308
