HP ProBook 455 G1 DVD/CD Drive Replacement
    1. HP ProBook 455 G1 DVD/CD Drive  Replacement, Battery: step 1, image 1 of 1
      • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
      • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
      Ask FixBot
    2. HP ProBook 455 G1 DVD/CD Drive  Replacement: step 2, image 1 of 1
      • Slide the two battery release latches towards the center of the laptop to release the battery.
      Ask FixBot
    3. HP ProBook 455 G1 DVD/CD Drive  Replacement: step 3, image 1 of 2 HP ProBook 455 G1 DVD/CD Drive  Replacement: step 3, image 2 of 2
      • Tilt the battery upward.
      • Remove it from the laptop.
      Ask FixBot
    1. HP ProBook 455 G1 DVD/CD Drive  Replacement, Service Panel: step 4, image 1 of 1
      • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
      Ask FixBot
    2. HP ProBook 455 G1 DVD/CD Drive  Replacement: step 5, image 1 of 2 HP ProBook 455 G1 DVD/CD Drive  Replacement: step 5, image 2 of 2
      • Slide the service panel toward you using your thumbs.
      • Lift it to remove the panel and reveal inner components of the computer.
      Ask FixBot
    1. HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: step 6, image 1 of 2 HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: step 6, image 2 of 2
      • Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
      • It will be located in the upper left section of the computer, housed in a small square hole in the computer frame.
      • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
      Ask FixBot
    2. HP ProBook 455 G1 DVD/CD Drive  Replacement: step 7, image 1 of 1
      • Using the screwdriver, gently push the silver tab that the screw secured to the left to release the DVD/CD drive from the computer.
      Ask FixBot
    3. HP ProBook 455 G1 DVD/CD Drive  Replacement: step 8, image 1 of 1
      • The DVD/CD drive will be extended from the side of the laptop. Slowly remove it from the computer.
      Ask FixBot
Jennifer Sexton
673 Reputation
4 Guides authored
Baylor, Team S5-G1, Williams Spring 2018 Member of Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 69
All Time: 1,457
