Up to 20% off select tools
HP ProBook 4540s WLAN Module Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
135
All Time:
2,914
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The WLAN module is used to power the Wi-Fi on the ProBook; not to be confused with the WWAN module that powers mobile broadband. The two modules are beside each other but the smaller module is WLAN which will be the focus for this guide.
    1. HP ProBook 4540s WLAN Module Replacement, Battery: step 1, image 1 of 1
      • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
      • Slide the two release latches on either side of the battery.
      • Gently tilt the battery upward and remove it from its socket.
      Ask FixBot
    1. HP ProBook 4540s WLAN Module Replacement, Bottom Door: step 2, image 1 of 1
      • Turn the computer so the bottom is facing towards you.
      • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
      • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
      • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
      Ask FixBot
    1. HP ProBook 4540s WLAN Module Replacement, WLAN Module: step 3, image 1 of 2 HP ProBook 4540s WLAN Module Replacement, WLAN Module: step 3, image 2 of 2
      • Disconnect the antenna cables from their terminals in the WLAN module.
      • One cable is attached to the Auxiliary ("Aux") terminal, represented with a blue wire. The other cable is connected to the Main terminal which is usually represented with a red wire. These wires can be seen in little windows beside the component.
      Ask FixBot
    2. HP ProBook 4540s WLAN Module Replacement: step 4, image 1 of 2 HP ProBook 4540s WLAN Module Replacement: step 4, image 2 of 2
      • Unscrew two 3.0 mm Phillips PM2.0x3.0 screw securing the module to the computer.
      • The edge of the module that is opposite of the slot is risen away from the computer.
      • Gently lift and remove the module.
      Ask FixBot
2 other people completed this guide.
Author
with
Amber Schindler
1,144 Reputation
6 Guides authored
UW Tacoma, Team 1-5, Rose Fall 2016 Member of UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 135
All Time: 2,914
