HP ProBook 4530s WiFi Card Replacement
    1. HP ProBook 4530s WiFi Card Replacement, Introduction: step 1, image 1 of 2 HP ProBook 4530s WiFi Card Replacement, Introduction: step 1, image 2 of 2
      • Start by flipping over the laptop onto its back.
      Ask FixBot
    2. HP ProBook 4530s WiFi Card Replacement, Battery Removal: step 2, image 1 of 1
      • Push both switches inward. The battery should pop out a slight amount.
      • Pull out the battery.
      Ask FixBot
    3. HP ProBook 4530s WiFi Card Replacement, Back Panel Removal: step 3, image 1 of 1
      • Press on both of the battery switches then push on the back panel forward.
      • It should pop out slightly.
      • Lift and slide the panel off.
      Ask FixBot
    4. HP ProBook 4530s WiFi Card Replacement, Connector Removal: step 4, image 1 of 2 HP ProBook 4530s WiFi Card Replacement, Connector Removal: step 4, image 2 of 2
      • Locate the WiFi card outlined in red.
      • The golden connectors will need to be popped off. They are marked in blue.
      • Be very careful. If these connectors break, you will have to buy entirely new wires and connectors.
      • Use a nail, a flat-head screwdriver, anything that will be able to pop off the connector gently.
      Ask FixBot
    5. HP ProBook 4530s WiFi Card Replacement, Card Removal: step 5, image 1 of 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: step 5, image 2 of 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: step 5, image 3 of 3
      • Remove the two screws that secure the card down.
      • The card should pop up at a 45 degree angle.
      • Pull the card straight out.
      Ask FixBot
7 other people completed this guide.
Drew Canada
1,490 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 97
All Time: 4,719
