Up to 20% off select tools
HP ProBook 4530s RAM Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
103
All Time:
4,106
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Very easy
Community-Contributed Guide
    1. HP ProBook 4530s RAM Replacement, Introduction: step 1, image 1 of 1
      • Start by flipping the laptop over onto its back.
      Ask FixBot
    2. HP ProBook 4530s RAM Replacement, Battery Removal: step 2, image 1 of 1
      • Press in on both sides, the switches will release the battery.
      • The battery will pop out slightly, allowing you to pull it out.
      Ask FixBot
    3. HP ProBook 4530s RAM Replacement, Bottom Panel Removal: step 3, image 1 of 1
      • Press in on both switches, while pushing onto the plastic panel behind them.
      • The panel should slide out.
      Ask FixBot
    4. HP ProBook 4530s RAM Replacement, Locate and Disassemble: step 4, image 1 of 3 HP ProBook 4530s RAM Replacement, Locate and Disassemble: step 4, image 2 of 3 HP ProBook 4530s RAM Replacement, Locate and Disassemble: step 4, image 3 of 3
      • Locate the RAM slightly to the center-left.
      • Press outward on the metal retention arms for the RAM.
      • The RAM should pop upward slightly.
      Ask FixBot
    5. HP ProBook 4530s RAM Replacement, RAM Removal: step 5, image 1 of 1
      • Grab the RAM gently and remove at a 45 Degree angle.
      Ask FixBot
6 other people completed this guide.
Author
with
Drew Canada
1,490 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 103
All Time: 4,106
