HP ProBook 4530s Hard Drive Replacement
    1. HP ProBook 4530s Hard Drive Replacement, Introduction: step 1, image 1 of 2 HP ProBook 4530s Hard Drive Replacement, Introduction: step 1, image 2 of 2
      • Start by flipping over the laptop onto its back.
      Ask FixBot
    2. HP ProBook 4530s Hard Drive Replacement, Battery Removal: step 2, image 1 of 2 HP ProBook 4530s Hard Drive Replacement, Battery Removal: step 2, image 2 of 2
      • Press inward on the two switches.
      • The battery should pop out slightly.
      • Remove the battery.
      Ask FixBot
    3. HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: step 3, image 1 of 2 HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: step 3, image 2 of 2
      • Press inward on both switches while pushing the center panel away from you. It should slide slightly backwards.
      • Release the switches.
      • Slide the panel the rest of the way out.
      Ask FixBot
    4. HP ProBook 4530s Hard Drive Replacement, Removing HDD: step 4, image 1 of 2 HP ProBook 4530s Hard Drive Replacement, Removing HDD: step 4, image 2 of 2
      • Unscrew the four screws located on the edges of the base.
      • Lift enough on the right side of the HDD to make it over the plastic paneling.
      • Pull outward.
      Ask FixBot
    5. HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: step 5, image 1 of 3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: step 5, image 2 of 3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: step 5, image 3 of 3
      • Remove the adhesive from the protective covering over the HDD.
      • Remove the four screws around the edges of the metal base.
      • Pull out the HDD from the base.
      Ask FixBot
    6. HP ProBook 4530s Hard Drive Replacement, Conclusion: step 6, image 1 of 1
      • Insert the new HDD or SSD.
      Ask FixBot
9 other people completed this guide.
Drew Canada
1,490 Reputation
4 Guides authored
2 Guide Comments
Clear and easy instructions. It’s nice to encounter a computer with such easy access to the internals.
Lensyl Urbano - Reply Share
You have saved me time and money from going to my engineer to help me out. Thank you.
Mercy Ayinde - Reply Share
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 162
All Time: 15,164
