Up to 20% off select tools
HP ProBook 4520s Screen Replacement
Views: 7.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
33
Past 30 Days:
154
All Time:
7,460
Comments: 2
2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your laptop screen is cracked or appears dark while the computer is running, replace the screen.
    1. HP ProBook 4520s Screen Replacement, Battery: step 1, image 1 of 2 HP ProBook 4520s Screen Replacement, Battery: step 1, image 2 of 2
      • Flip the 4520s upside-down with the front toward you.
      • Push the two latches below the battery inwards at the same time.
      Ask FixBot
    2. HP ProBook 4520s Screen Replacement: step 2, image 1 of 1
      • Remove the battery by holding the latches and sliding the battery away from you.
      Ask FixBot
    1. HP ProBook 4520s Screen Replacement, Switch Cover: step 3, image 1 of 2 HP ProBook 4520s Screen Replacement, Switch Cover: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
      Ask FixBot
    2. HP ProBook 4520s Screen Replacement: step 4, image 1 of 2 HP ProBook 4520s Screen Replacement: step 4, image 2 of 2
      • Flip the 4520s over and rotate it so the back is facing you.
      • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
      Ask FixBot
    3. HP ProBook 4520s Screen Replacement: step 5, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
      Ask FixBot
    4. HP ProBook 4520s Screen Replacement: step 6, image 1 of 3 HP ProBook 4520s Screen Replacement: step 6, image 2 of 3 HP ProBook 4520s Screen Replacement: step 6, image 3 of 3
      • Rotate the 4520s and then open it with the screen facing you.
      • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
      • Lift the switch cover away from the 4520s and set it aside.
      Ask FixBot
    1. HP ProBook 4520s Screen Replacement, Screen: step 7, image 1 of 2 HP ProBook 4520s Screen Replacement, Screen: step 7, image 2 of 2
      • Use a metal spudger to remove four rubber caps at the bottom of the screen border.
      Ask FixBot
    2. HP ProBook 4520s Screen Replacement: step 8, image 1 of 2 HP ProBook 4520s Screen Replacement: step 8, image 2 of 2
      • Use a Torx (T9) head screwdriver to remove the four 5mm screws beneath the rubber caps.
      Ask FixBot
    3. HP ProBook 4520s Screen Replacement: step 9, image 1 of 3 HP ProBook 4520s Screen Replacement: step 9, image 2 of 3 HP ProBook 4520s Screen Replacement: step 9, image 3 of 3
      • Pry open the tabs behind the border of the screen using a metal spudger.
      • Set the border of the screen aside.
      Ask FixBot
    4. HP ProBook 4520s Screen Replacement: step 10, image 1 of 2 HP ProBook 4520s Screen Replacement: step 10, image 2 of 2
      • Use a Torx (T9) head screwdriver to remove two 5mm screws above the screen, and two more screws below it.
      • The bottom set of screws is installed on the innermost screw holes.
      Ask FixBot
    5. HP ProBook 4520s Screen Replacement: step 11, image 1 of 1
      • Above the screen is a bronze port with a cable connected to it. Disconnect the cable using a metal spudger or your finger.
      Ask FixBot
    6. HP ProBook 4520s Screen Replacement: step 12, image 1 of 1
      • Gently push the back cover away.
      Ask FixBot
    7. HP ProBook 4520s Screen Replacement: step 13, image 1 of 3 HP ProBook 4520s Screen Replacement: step 13, image 2 of 3 HP ProBook 4520s Screen Replacement: step 13, image 3 of 3
      • Use a Phillips (PH1) head screwdriver to remove eight 2mm screws from the screen. Four of the screws will be on the left side and four will be on the right.
      • Place the screen face down.
      Ask FixBot
    8. HP ProBook 4520s Screen Replacement: step 14, image 1 of 3 HP ProBook 4520s Screen Replacement: step 14, image 2 of 3 HP ProBook 4520s Screen Replacement: step 14, image 3 of 3
      • Peel the ribbon cable away from the screen.
      Ask FixBot
    9. HP ProBook 4520s Screen Replacement: step 15, image 1 of 2 HP ProBook 4520s Screen Replacement: step 15, image 2 of 2
      • To open the clamp for the ribbon cable, use a spudger to pry up the metal bar securing it to the screen.
      • Disconnect the cable after freeing it from the metal bar
      Ask FixBot
7 other people completed this guide.
Author
with
Robert Spencer Harrison
1,422 Reputation
4 Guides authored
UC Davis, Team 1-3, Oliver Fall 2016 Member of UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Members
84 Guides authored
2 Guide Comments
I need back cover hp i5 probook 4520s
amir86216 - Reply Share
I need speakers hp probook 4520s i5
Osagie Rmd - Reply Share
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 154
All Time: 7,460
