HP ProBook 4520s Optical Drive Replacement
    1. HP ProBook 4520s Optical Drive Replacement, Battery: step 1, image 1 of 2 HP ProBook 4520s Optical Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the 4520s upside-down with the front toward you.
      • Push the two latches below the battery inwards at the same time.
      Ask FixBot
    2. HP ProBook 4520s Optical Drive Replacement: step 2, image 1 of 1
      • Remove the battery by holding the latches and sliding the battery away from you.
      Ask FixBot
    1. HP ProBook 4520s Optical Drive Replacement, Switch Cover: step 3, image 1 of 2 HP ProBook 4520s Optical Drive Replacement, Switch Cover: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
      Ask FixBot
    2. HP ProBook 4520s Optical Drive Replacement: step 4, image 1 of 2 HP ProBook 4520s Optical Drive Replacement: step 4, image 2 of 2
      • Flip the 4520s over and rotate it so the back is facing you.
      • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
      Ask FixBot
    3. HP ProBook 4520s Optical Drive Replacement: step 5, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
      Ask FixBot
    4. HP ProBook 4520s Optical Drive Replacement: step 6, image 1 of 3 HP ProBook 4520s Optical Drive Replacement: step 6, image 2 of 3 HP ProBook 4520s Optical Drive Replacement: step 6, image 3 of 3
      • Rotate the 4520s and then open it with the screen facing you.
      • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
      • Lift the switch cover away from the 4520s and set it aside.
      Ask FixBot
    1. HP ProBook 4520s Optical Drive Replacement, Keyboard: step 7, image 1 of 2 HP ProBook 4520s Optical Drive Replacement, Keyboard: step 7, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
      Ask FixBot
    2. HP ProBook 4520s Optical Drive Replacement: step 8, image 1 of 1
      • Slide the keyboard panel away from you to free it from the 4520s.
      • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
      Ask FixBot
    3. HP ProBook 4520s Optical Drive Replacement: step 9, image 1 of 2 HP ProBook 4520s Optical Drive Replacement: step 9, image 2 of 2
      • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
      • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
      • Remove the cable and lift the keyboard panel up. Set it aside.
      • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
      Ask FixBot
    1. HP ProBook 4520s Optical Drive Replacement, Optical Drive: step 10, image 1 of 2 HP ProBook 4520s Optical Drive Replacement, Optical Drive: step 10, image 2 of 2
      • The housing for the optical drive is on the right of the device.
      • Remove the 5mm screw on the left side of the metal plate with a Phillips (PH1) head screwdriver.
      Ask FixBot
    2. HP ProBook 4520s Optical Drive Replacement: step 11, image 1 of 1
      • Use a metal spudger to push the optical drive to the right and partially out of the casing.
      Ask FixBot
    3. HP ProBook 4520s Optical Drive Replacement: step 12, image 1 of 1
      • Slide the optical drive outward from the 4520s.
      Ask FixBot
    4. HP ProBook 4520s Optical Drive Replacement: step 13, image 1 of 2 HP ProBook 4520s Optical Drive Replacement: step 13, image 2 of 2
      • Use a Phillips (PH1) head screwdriver to remove two 2mm screws securing the metal tab to the optical drive.
      Ask FixBot
Nicholas Caruso
326 Reputation
1 Guide authored
UC Davis, Team 1-3, Oliver Fall 2016 Member of UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 124
All Time: 3,068
