Up to 20% off select tools
HP ProBook 4520s Keyboard Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
130
All Time:
5,707
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If the keys on your keyboard are unresponsive or damaged, remove the keyboard for cleaning or replacement.
    1. HP ProBook 4520s Keyboard Replacement, Battery: step 1, image 1 of 2 HP ProBook 4520s Keyboard Replacement, Battery: step 1, image 2 of 2
      • Flip the 4520s upside-down with the front toward you.
      • Push the two latches below the battery inwards at the same time.
      Ask FixBot
    2. HP ProBook 4520s Keyboard Replacement: step 2, image 1 of 1
      • Remove the battery by holding the latches and sliding the battery away from you.
      Ask FixBot
    1. HP ProBook 4520s Keyboard Replacement, Switch Cover: step 3, image 1 of 2 HP ProBook 4520s Keyboard Replacement, Switch Cover: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
      Ask FixBot
    2. HP ProBook 4520s Keyboard Replacement: step 4, image 1 of 2 HP ProBook 4520s Keyboard Replacement: step 4, image 2 of 2
      • Flip the 4520s over and rotate it so the back is facing you.
      • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
      Ask FixBot
    3. HP ProBook 4520s Keyboard Replacement: step 5, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
      Ask FixBot
    4. HP ProBook 4520s Keyboard Replacement: step 6, image 1 of 3 HP ProBook 4520s Keyboard Replacement: step 6, image 2 of 3 HP ProBook 4520s Keyboard Replacement: step 6, image 3 of 3
      • Rotate the 4520s and then open it with the screen facing you.
      • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
      • Lift the switch cover away from the 4520s and set it aside.
      Ask FixBot
    1. HP ProBook 4520s Keyboard Replacement, Keyboard: step 7, image 1 of 2 HP ProBook 4520s Keyboard Replacement, Keyboard: step 7, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
      Ask FixBot
    2. HP ProBook 4520s Keyboard Replacement: step 8, image 1 of 1
      • Slide the keyboard panel away from you to free it from the 4520s.
      • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
      Ask FixBot
    3. HP ProBook 4520s Keyboard Replacement: step 9, image 1 of 2 HP ProBook 4520s Keyboard Replacement: step 9, image 2 of 2
      • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
      • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
      • Remove the cable and lift the keyboard panel up. Set it aside.
      • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
7 other people completed this guide.
Author
with
Robert Spencer Harrison
1,422 Reputation
4 Guides authored
UC Davis, Team 1-3, Oliver Fall 2016 Member of UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Members
84 Guides authored
1 Guide Comment
hp probook 4520s disassembly
https://youtu.be/8749zmz0lls
mohamed - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 130
All Time: 5,707
