HP ProBook 450 G6 Touchpad Assembly Replacement
    1. HP ProBook 450 G6 Touchpad Assembly Replacement, Lower Case: step 1, image 1 of 1
      • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
      • Loosen the five captive Phillips 8.2 mm screws securing the lower case.
      • Remove the two 5 mm Phillips screws securing the lower case.
      Ask FixBot
    2. HP ProBook 450 G6 Touchpad Assembly Replacement: step 2, image 1 of 2 HP ProBook 450 G6 Touchpad Assembly Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
      • Remove the lower case.
      Ask FixBot
    1. HP ProBook 450 G6 Touchpad Assembly Replacement, Battery: step 3, image 1 of 1
      • Remove the three Phillips M2.0x4.0 screws that are securing the battery.
      Ask FixBot
    2. HP ProBook 450 G6 Touchpad Assembly Replacement: step 4, image 1 of 3 HP ProBook 450 G6 Touchpad Assembly Replacement: step 4, image 2 of 3 HP ProBook 450 G6 Touchpad Assembly Replacement: step 4, image 3 of 3
      • Rotate the top of the battery up and lift the battery out of the Probook.
      Ask FixBot
    1. HP ProBook 450 G6 Touchpad Assembly Replacement, Touchpad Assembly: step 5, image 1 of 1
      • Flip up the black locking flap securing the touchpad ribbon cable.
      • Disconnect the touchpad ribbon cable.
      Ask FixBot
    2. HP ProBook 450 G6 Touchpad Assembly Replacement: step 6, image 1 of 2 HP ProBook 450 G6 Touchpad Assembly Replacement: step 6, image 2 of 2
      • Remove the six M2.0x2.0 Phillips screws securing the touchpad.
      Ask FixBot
    3. HP ProBook 450 G6 Touchpad Assembly Replacement: step 7, image 1 of 2 HP ProBook 450 G6 Touchpad Assembly Replacement: step 7, image 2 of 2
      • Lift and remove the touchpad.
      • Lift/remove any silver type securing the touchpad as needed.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kaleb Rettig
127 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 68
All Time: 209
