HP ProBook 450 G6 Lower Case Replacement
    1. HP ProBook 450 G6 Lower Case Replacement, Lower Case: step 1, image 1 of 1
      • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
      • Loosen the five captive Phillips 8.2 mm screws securing the lower case.
      • Remove the two 5 mm Phillips screws securing the lower case.
      Ask FixBot
    2. HP ProBook 450 G6 Lower Case Replacement: step 2, image 1 of 2 HP ProBook 450 G6 Lower Case Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
      • Remove the lower case.
      Ask FixBot
Connor Bassolino
26,159 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 92
All Time: 247
