HP ProBook 450 G6 Battery Replacement
    1. HP ProBook 450 G6 Battery Replacement, Lower Case: step 1, image 1 of 1
      • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
      • Loosen the five captive Phillips 8.2 mm screws securing the lower case.
      • Remove the two 5 mm Phillips screws securing the lower case.
      Ask FixBot
    2. HP ProBook 450 G6 Battery Replacement: step 2, image 1 of 2 HP ProBook 450 G6 Battery Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
      • Remove the lower case.
      Ask FixBot
    1. HP ProBook 450 G6 Battery Replacement, Battery: step 3, image 1 of 1
      • Remove the three Phillips M2.0x4.0 screws that are securing the battery.
      Ask FixBot
    2. HP ProBook 450 G6 Battery Replacement: step 4, image 1 of 3 HP ProBook 450 G6 Battery Replacement: step 4, image 2 of 3 HP ProBook 450 G6 Battery Replacement: step 4, image 3 of 3
      • Rotate the top of the battery up and lift the battery out of the Probook.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 223
All Time: 607
