HP ProBook 450 G4 Fan Replacement
    1. HP ProBook 450 G4 Fan Replacement, Hard Drive: step 1, image 1 of 2 HP ProBook 450 G4 Fan Replacement, Hard Drive: step 1, image 2 of 2
      • Power your laptop off.
      • Flip the laptop over.
      • Orient the laptop so the two vents on the bottom face upward and are further away from you.
      Ask FixBot
    2. HP ProBook 450 G4 Fan Replacement: step 2, image 1 of 3 HP ProBook 450 G4 Fan Replacement: step 2, image 2 of 3 HP ProBook 450 G4 Fan Replacement: step 2, image 3 of 3
      • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
      • Use the spudger to separate the vent panel from the laptop.
      • Slide the vent panel off the backside of the laptop.
      Ask FixBot
    3. HP ProBook 450 G4 Fan Replacement: step 3, image 1 of 2 HP ProBook 450 G4 Fan Replacement: step 3, image 2 of 2
      • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
      Ask FixBot
    4. HP ProBook 450 G4 Fan Replacement: step 4, image 1 of 2 HP ProBook 450 G4 Fan Replacement: step 4, image 2 of 2
      • Use the spudger to lift the left side of the hard drive up.
      • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
      Ask FixBot
    1. HP ProBook 450 G4 Fan Replacement, Keyboard: step 5, image 1 of 3 HP ProBook 450 G4 Fan Replacement, Keyboard: step 5, image 2 of 3 HP ProBook 450 G4 Fan Replacement, Keyboard: step 5, image 3 of 3
      • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
      • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
      Ask FixBot
    2. HP ProBook 450 G4 Fan Replacement: step 6, image 1 of 3 HP ProBook 450 G4 Fan Replacement: step 6, image 2 of 3 HP ProBook 450 G4 Fan Replacement: step 6, image 3 of 3
      • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
      • Apply pressure to the black tabs until they release and pop out.
      Ask FixBot
    3. HP ProBook 450 G4 Fan Replacement: step 7, image 1 of 3 HP ProBook 450 G4 Fan Replacement: step 7, image 2 of 3 HP ProBook 450 G4 Fan Replacement: step 7, image 3 of 3
      • Orient the laptop so the keyboard is facing upwards and towards you.
      • Insert the spudger in between the edge of the keyboard and the computer frame.
      • Slide the spudger around the edge of the keyboard until the keyboard is loose.
      • Gently pull the keyboard away from the body of the laptop.
      • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
      Ask FixBot
    4. HP ProBook 450 G4 Fan Replacement: step 8, image 1 of 2 HP ProBook 450 G4 Fan Replacement: step 8, image 2 of 2
      • Use a spudger to gently lift up the black locking bar on the keyboard connector.
      • Slide the keyboard ribbon out of the connector.
      • Remove the keyboard.
      • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
      Ask FixBot
    1. HP ProBook 450 G4 Fan Replacement, Battery: step 9, image 1 of 2 HP ProBook 450 G4 Fan Replacement, Battery: step 9, image 2 of 2
      • Flip the laptop back over.
      • Remove the eight 6.8mm T8 Torx screws on the backside of the laptop.
      Ask FixBot
    2. HP ProBook 450 G4 Fan Replacement: step 10, image 1 of 2 HP ProBook 450 G4 Fan Replacement: step 10, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the three 6.6mm screws from the upper left corner of the laptop.
      Ask FixBot
    3. HP ProBook 450 G4 Fan Replacement: step 11, image 1 of 2 HP ProBook 450 G4 Fan Replacement: step 11, image 2 of 2
      • Use the spudger to slide the disk drive out of the laptop.
      • Use the Phillips #0 screwdriver to remove the two 3.2mm screws that are underneath where the disk drive previously was.
      Ask FixBot
    4. HP ProBook 450 G4 Fan Replacement: step 12, image 1 of 3 HP ProBook 450 G4 Fan Replacement: step 12, image 2 of 3 HP ProBook 450 G4 Fan Replacement: step 12, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
      Ask FixBot
    5. HP ProBook 450 G4 Fan Replacement: step 13, image 1 of 2 HP ProBook 450 G4 Fan Replacement: step 13, image 2 of 2
      • Flip the laptop back over so it is facing upwards.
      • Remove the six 6.6mm T8 Torx screws underneath where the keyboard used to be.
      Ask FixBot
    6. HP ProBook 450 G4 Fan Replacement: step 14, image 1 of 3 HP ProBook 450 G4 Fan Replacement: step 14, image 2 of 3 HP ProBook 450 G4 Fan Replacement: step 14, image 3 of 3
      • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
      • Be extra careful while disconnecting the cable connectors because they can tear easily.
      Ask FixBot
    7. HP ProBook 450 G4 Fan Replacement: step 15, image 1 of 2 HP ProBook 450 G4 Fan Replacement: step 15, image 2 of 2
      • Insert the spudger in between the top case of the laptop and its outer frame.
      • Slide the spudger around the edge of the laptop until the top case comes off.
      • Remove the top case.
      Ask FixBot
    8. HP ProBook 450 G4 Fan Replacement: step 16, image 1 of 2 HP ProBook 450 G4 Fan Replacement: step 16, image 2 of 2
      • Insert the opening tool underneath the left side of the battery to remove it from the laptop.
      Ask FixBot
    1. HP ProBook 450 G4 Fan Replacement, Fan: step 17, image 1 of 3 HP ProBook 450 G4 Fan Replacement, Fan: step 17, image 2 of 3 HP ProBook 450 G4 Fan Replacement, Fan: step 17, image 3 of 3
      • Use the spudger to disconnect the two cable connectors that secure the fan to the laptop.
      Ask FixBot
    2. HP ProBook 450 G4 Fan Replacement: step 18, image 1 of 1
      • Insert the spudger underneath the black wire that wraps over the top of the fan.
      • Use the spudger to pull the black wire away from the top of the fan.
      Ask FixBot
    3. HP ProBook 450 G4 Fan Replacement: step 19, image 1 of 2 HP ProBook 450 G4 Fan Replacement: step 19, image 2 of 2
      • Use a TR9 Torx screwdriver to remove the 6.6mm black screw directly above the fan.
      Ask FixBot
    4. HP ProBook 450 G4 Fan Replacement: step 20, image 1 of 1
      • Insert the spudger under the right side of the fan.
      • Use the spudger to gently lift the fan from the laptop.
      Ask FixBot
5 other people completed this guide.
Sebastian Dow
1,142 Reputation
6 Guides authored
Cal Poly, Team S1-G3, White Winter 2020 Member of Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 90
All Time: 3,830
