HP ProBook 450 G4 Display Assembly Replacement
    1. HP ProBook 450 G4 Display Assembly Replacement, Back Panel: step 1, image 1 of 2 HP ProBook 450 G4 Display Assembly Replacement, Back Panel: step 1, image 2 of 2
      • Power off your laptop and flip it over so that the bottom faces upward.
      • Use the Phillips #0 screwdriver to remove the screw securing the service door.
      • Use a Jimmy to remove the service door.
      Ask FixBot
    1. HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: step 2, image 1 of 2 HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
      • Remove the black 3.2mm screw that secures the hard drive to the left side of the laptop with a Phillips #0 screwdriver.
      • Use the spudger to lift the left side of the hard drive, and remove.
      Ask FixBot
    2. HP ProBook 450 G4 Display Assembly Replacement: step 3, image 1 of 2 HP ProBook 450 G4 Display Assembly Replacement: step 3, image 2 of 2
      • Remove all 6.6 mm T8 Torx screws, including where the hard drive used to be.
      Ask FixBot
    3. HP ProBook 450 G4 Display Assembly Replacement: step 4, image 1 of 2 HP ProBook 450 G4 Display Assembly Replacement: step 4, image 2 of 2
      • Unclip the wires from the Wi-Fi card.
      • Remove the Wi-Fi card.
      Ask FixBot
    4. HP ProBook 450 G4 Display Assembly Replacement: step 5, image 1 of 3 HP ProBook 450 G4 Display Assembly Replacement: step 5, image 2 of 3 HP ProBook 450 G4 Display Assembly Replacement: step 5, image 3 of 3
      • Flip the laptop over, and use a Jimmy to loosen the keypad from the laptop.
      • Use the spudger to unclip the tab.
      • Remove the top case once all tabs are loose.
      Ask FixBot
    5. HP ProBook 450 G4 Display Assembly Replacement: step 6, image 1 of 1
      • Use the spudger to disconnect the black wire.
      Ask FixBot
    6. HP ProBook 450 G4 Display Assembly Replacement: step 7, image 1 of 2 HP ProBook 450 G4 Display Assembly Replacement: step 7, image 2 of 2
      • Use the Phillips #0 screwdriver to remove the two 3.2mm screws from the hinges.
      • Repeat on both sides.
      Ask FixBot
    7. HP ProBook 450 G4 Display Assembly Replacement: step 8, image 1 of 1
      • Remove and replace the display assembly.
      Ask FixBot
Nat Robinson
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 129
All Time: 992
