Up to 20% off select tools
HP ProBook 450 G2
Views: 5.7K
View statistics:
Past 24 Hours:
15
Past 7 Days:
72
Past 30 Days:
334
All Time:
5,737
Comments: 2
2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
HP ProBook 450 G2
Tools
    1. HP ProBook 450 G2, Detaching the Bottom Cover and Battery: step 1, image 1 of 2 HP ProBook 450 G2, Detaching the Bottom Cover and Battery: step 1, image 2 of 2
      • Carefully remove the main battery.
      • Locate the screw on the bottom side.
      • Unscrew and remove it.
      • Carefully take off the two plastic covers.
      Ask FixBot
    2. HP ProBook 450 G2, Disassembling the Keyboard: step 2, image 1 of 3 HP ProBook 450 G2, Disassembling the Keyboard: step 2, image 2 of 3 HP ProBook 450 G2, Disassembling the Keyboard: step 2, image 3 of 3
      • Locate the three screws marked with a keyboard icon next to them.
      • Carefully unscrew and remove each of them.
      • Take a thin, flat tool, such as a guitar pick.
      • Gently insert it at the top edge of the keyboard.
      • Carefully slide it along the edge until the keyboard starts to lift or "pop" out.
      • Do not immediately pull out the keyboard.
      • Carefully locate and detach the keyboard cable connecting it to the motherboard.
      Ask FixBot
    3. HP ProBook 450 G2, Detaching the CD/DVD Drive Unit: step 3, image 1 of 2 HP ProBook 450 G2, Detaching the CD/DVD Drive Unit: step 3, image 2 of 2
      • Locate the screw marked with a CD icon next to it.
      • Carefully unscrew and remove it.
      • Carefully pull out the CD-DVD unit.
      Ask FixBot
    4. HP ProBook 450 G2, Extracting the Hard Drive: step 4, image 1 of 2 HP ProBook 450 G2, Extracting the Hard Drive: step 4, image 2 of 2
      • Locate the four screws marked.
      • Slide the disk to the right and then carefully pull it out.
      Ask FixBot
    5. HP ProBook 450 G2, Disassembling the Casing (1/2): step 5, image 1 of 3 HP ProBook 450 G2, Disassembling the Casing (1/2): step 5, image 2 of 3 HP ProBook 450 G2, Disassembling the Casing (1/2): step 5, image 3 of 3
      • On the bottom locate the 11 (M2.5x3) screws marked and 2 (M2.5x6) - picture 1.
      • On the bottom locate the 6 (M2.5x6) screws hidden under the rubbers - picture 2.
      • Under the keyboard locate the 3 (M2.5x6) screws.
      • Detach all cables connected to the motherboard.
      Ask FixBot
    6. HP ProBook 450 G2, Disassembling the Casing (2/2): step 6, image 1 of 2 HP ProBook 450 G2, Disassembling the Casing (2/2): step 6, image 2 of 2
      • Carefully separate the covers.
      • Be aware that there is an additional cable underneath. Detach this cable with caution.
      Ask FixBot
    7. HP ProBook 450 G2, Extracting the Motherboard: step 7, image 1 of 1
      • Locate the five screws marked.
      • To more easily access and detach the cables, gently pull out the motherboard a bit.
      Ask FixBot
    8. HP ProBook 450 G2, Dismantle cpu cooling pipe: step 8, image 1 of 2 HP ProBook 450 G2, Dismantle cpu cooling pipe: step 8, image 2 of 2
      • Locate the six screws marked.
      • Now you can take off cooling pipe and clean it.
      Ask FixBot
5 other people completed this guide.
Author
with
Klemen Hodžić
764 Reputation
4 Guides authored
2 Guide Comments
thanks for computer education
kagizo - Reply Share
شكرا ليكم على الشرح
Abdo elmasry - Reply Share
Past 24 Hours: 15
Past 7 Days: 72
Past 30 Days: 334
All Time: 5,737
