HP ProBook 440 G9 Trackpad Replacement
    1. HP ProBook 440 G9 Trackpad Replacement, Remove Bottom Cover: step 1, image 1 of 2 HP ProBook 440 G9 Trackpad Replacement, Remove Bottom Cover: step 1, image 2 of 2
      • Use Phillips #01 screwdriver to unscrew all 6 threaded screws.
      • Do not remove screws from bottom cover as they are intended to stay attached to the bottom cover.
      • Use guitar pick tool to unclip the back cover all around the edges starting from the top.
      Ask FixBot
    2. HP ProBook 440 G9 Trackpad Replacement, Remove Battery: step 2, image 1 of 3 HP ProBook 440 G9 Trackpad Replacement, Remove Battery: step 2, image 2 of 3 HP ProBook 440 G9 Trackpad Replacement, Remove Battery: step 2, image 3 of 3
      • Remove all 4 screws from the battery.
      • Disconnect the Battery Connector from the motherboard using the side tabs on the connector.
      • Possible spark may occur at the Battery Connector port if laptop is not fully powered off when replacing the laptop battery.
      • Remove the battery from the laptop.
      Ask FixBot
    1. HP ProBook 440 G9 Trackpad Replacement, Detach Trackpad: step 3, image 1 of 3 HP ProBook 440 G9 Trackpad Replacement, Detach Trackpad: step 3, image 2 of 3 HP ProBook 440 G9 Trackpad Replacement, Detach Trackpad: step 3, image 3 of 3
      • Unscrew 4 screws with Phillips #01 screwdriver.
      • Unscrew 2 screws with the Phillips #00 screwdriver.
      • Unlatch the trackpad connector.
      • Pull the tab on the trackpad ribbon straight out from the connector.
      • Trackpad ribbon cable can be easily damaged.
      Ask FixBot
    2. HP ProBook 440 G9 Trackpad Replacement, Remove Trackpad: step 4, image 1 of 2 HP ProBook 440 G9 Trackpad Replacement, Remove Trackpad: step 4, image 2 of 2
      • Remove 2 silver tape attached to the trackpad frame.
      • Try to not tear tape strips but does not affect trackpad performance if they are damaged.
      • Remove trackpad from laptop frame.
      Ask FixBot
Joel
509 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 95
All Time: 750
