HP ProBook 440 G9 Solid State Drive Replacement
    1. HP ProBook 440 G9 Solid State Drive Replacement, Remove Bottom Cover: step 1, image 1 of 2 HP ProBook 440 G9 Solid State Drive Replacement, Remove Bottom Cover: step 1, image 2 of 2
      • Use Phillips #01 screwdriver to unscrew all 6 threaded screws.
      • Do not remove screws from bottom cover as they are intended to stay attached to the bottom cover.
      • Use guitar pick tool to unclip the back cover all around the edges starting from the top.
      Ask FixBot
    2. HP ProBook 440 G9 Solid State Drive Replacement, Remove Battery: step 2, image 1 of 3 HP ProBook 440 G9 Solid State Drive Replacement, Remove Battery: step 2, image 2 of 3 HP ProBook 440 G9 Solid State Drive Replacement, Remove Battery: step 2, image 3 of 3
      • Remove all 4 screws from the battery.
      • Disconnect the Battery Connector from the motherboard using the side tabs on the connector.
      • Possible spark may occur at the Battery Connector port if laptop is not fully powered off when replacing the laptop battery.
      • Remove the battery from the laptop.
      Ask FixBot
    1. HP ProBook 440 G9 Solid State Drive Replacement, Remove Solid State Drive: step 3, image 1 of 3 HP ProBook 440 G9 Solid State Drive Replacement, Remove Solid State Drive: step 3, image 2 of 3 HP ProBook 440 G9 Solid State Drive Replacement, Remove Solid State Drive: step 3, image 3 of 3
      • Use Phillips #00 to remove screw from SSD.
      • SSD will lift up at a 45 degree angle when screw is removed.
      • Remove SSD from the SSD slot.
      • When reinserting the SSD plug in at a 45 degree angle and then screw down with the new screw.
      Ask FixBot
Joel
509 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 33
Past 30 Days: 121
All Time: 1,296
