Community-Contributed Guide
Tools
Use Phillips #01 screwdriver to unscrew all 6 threaded screws.
Use guitar pick tool to unclip the back cover all around the edges starting from the top.
Remove all 4 screws from the battery.
Disconnect the Battery Connector from the motherboard using the side tabs on the connector.
Remove the battery from the laptop.
Use Phillips #00 to remove screw from SSD.
Remove SSD from the SSD slot.
Remove ribbon cables from daughter board.
Use Phillips #01 screwdriver to remove 4 screws from daughter board.
Remove the Ethernet port piece and set to the side.
Use Phillips #01 screwdriver to remove 3 screws from hinge.
Lift the display hinge to release the daughter board.
Lift the daughter board on the left part of the board to detach from the laptop port cutouts.
