HP ProBook 440 G6 Touchpad Replacement
    1. HP ProBook 440 G6 Touchpad Replacement, Lower Case: step 1, image 1 of 3 HP ProBook 440 G6 Touchpad Replacement, Lower Case: step 1, image 2 of 3 HP ProBook 440 G6 Touchpad Replacement, Lower Case: step 1, image 3 of 3
      • Using a Phillips #0 Screwdriver, remove the two 5 mm screws on the front-facing side of the lower case.
      • Using a Phillips #0 Screwdriver, remove the remaining five 5 mm Phillips screws securing the lower case.
      • The two screws in the front of the backplate are of a differing size to the other five.
      Ask FixBot
    2. HP ProBook 440 G6 Touchpad Replacement: step 2, image 1 of 3 HP ProBook 440 G6 Touchpad Replacement: step 2, image 2 of 3 HP ProBook 440 G6 Touchpad Replacement: step 2, image 3 of 3
      • Starting under the display, carefully use a plastic prying tool (iFixit opening tool) to disengage the retaining clips.
      • You may hear soft clicking sounds as the clips come undone.
      • Once a corner or edge starts to lift, slowly slide the tool along the edge to loosen more of the bottom panel.
      • Keep working around the edges until all the clips are loose.
      Ask FixBot
    3. HP ProBook 440 G6 Touchpad Replacement: step 3, image 1 of 3 HP ProBook 440 G6 Touchpad Replacement: step 3, image 2 of 3 HP ProBook 440 G6 Touchpad Replacement: step 3, image 3 of 3
      • Gently lift the rear of the cover to disengage it from the computer.
      • Carefully remove the bottom cover from the computer.
      Ask FixBot
    1. HP ProBook 440 G6 Touchpad Replacement, Battery: step 4, image 1 of 2 HP ProBook 440 G6 Touchpad Replacement, Battery: step 4, image 2 of 2
      • Using a Phillips #0 Screwdriver, remove the two 4mm Phillips screws that secure the battery to the computer.
      Ask FixBot
    2. HP ProBook 440 G6 Touchpad Replacement: step 5, image 1 of 1
      • Use a tool to push the tab back on the bottom left of the battery.
      Ask FixBot
    3. HP ProBook 440 G6 Touchpad Replacement: step 6, image 1 of 3 HP ProBook 440 G6 Touchpad Replacement: step 6, image 2 of 3 HP ProBook 440 G6 Touchpad Replacement: step 6, image 3 of 3
      • Lift the top of the battery.
      • Lift the battery out of the computer.
      Ask FixBot
    1. HP ProBook 440 G6 Touchpad Replacement, Touchpad: step 7, image 1 of 3 HP ProBook 440 G6 Touchpad Replacement, Touchpad: step 7, image 2 of 3 HP ProBook 440 G6 Touchpad Replacement, Touchpad: step 7, image 3 of 3
      • Use tweezers to carefully lift and disconnect the silver tape from the touchpad.
      • It may help to use a plastic prying tool, a spudger, to remove the silver tape.
      Ask FixBot
    2. HP ProBook 440 G6 Touchpad Replacement: step 8, image 1 of 3 HP ProBook 440 G6 Touchpad Replacement: step 8, image 2 of 3 HP ProBook 440 G6 Touchpad Replacement: step 8, image 3 of 3
      • Carefully lift the small black locking flap on the ZIF connector.
      • Disconnect the cable from the ZIF connector on the touchpad.
      Ask FixBot
    3. HP ProBook 440 G6 Touchpad Replacement: step 9, image 1 of 3 HP ProBook 440 G6 Touchpad Replacement: step 9, image 2 of 3 HP ProBook 440 G6 Touchpad Replacement: step 9, image 3 of 3
      • Using a Phillips #0 screwdriver, remove the six Phillips 2 mm screws that secure the touchpad.
      Ask FixBot
    4. HP ProBook 440 G6 Touchpad Replacement: step 10, image 1 of 3 HP ProBook 440 G6 Touchpad Replacement: step 10, image 2 of 3 HP ProBook 440 G6 Touchpad Replacement: step 10, image 3 of 3
      • Lift the touchpad out of the computer.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Elijah Cain
397 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 77
All Time: 272
