Up to 20% off select tools
HP ProBook 440 G6 RAM Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
123
All Time:
497
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Do you need to inspect or replace your RAM? In this guide, We'll demonstrate how to safely replace the RAM in your HP ProBook 440 g6 notebook.
The RAM stores all of the information your device needs to run its operating system. Programs and applications also store their data. Without the RAM, the device would become slow and very prone to errors.
Common Symptoms you may find due to a bad RAM may include:
  • Frequent system crashes or blue screens
  • Random unexplained system shutdowns
  • Applications freezing or crashing frequently
  • Distortion in graphics and other visual bugs
If you notice any of these symptoms, you may need to replace your RAM. However before beginning your replacement process, unsure to power off your device, unplug it from the charger, and put it in Battery Safe Mode.
    1. HP ProBook 440 G6 RAM Replacement, Lower Case: step 1, image 1 of 3 HP ProBook 440 G6 RAM Replacement, Lower Case: step 1, image 2 of 3 HP ProBook 440 G6 RAM Replacement, Lower Case: step 1, image 3 of 3
      • Using a Phillips #0 Screwdriver, remove the two 5 mm screws on the front-facing side of the lower case.
      • Using a Phillips #0 Screwdriver, remove the remaining five 5 mm Phillips screws securing the lower case.
      • The two screws in the front of the backplate are of a differing size to the other five.
      Ask FixBot
    2. HP ProBook 440 G6 RAM Replacement: step 2, image 1 of 3 HP ProBook 440 G6 RAM Replacement: step 2, image 2 of 3 HP ProBook 440 G6 RAM Replacement: step 2, image 3 of 3
      • Starting under the display, carefully use a plastic prying tool (iFixit opening tool) to disengage the retaining clips.
      • You may hear soft clicking sounds as the clips come undone.
      • Once a corner or edge starts to lift, slowly slide the tool along the edge to loosen more of the bottom panel.
      • Keep working around the edges until all the clips are loose.
      Ask FixBot
    3. HP ProBook 440 G6 RAM Replacement: step 3, image 1 of 3 HP ProBook 440 G6 RAM Replacement: step 3, image 2 of 3 HP ProBook 440 G6 RAM Replacement: step 3, image 3 of 3
      • Gently lift the rear of the cover to disengage it from the computer.
      • Carefully remove the bottom cover from the computer.
      Ask FixBot
    1. HP ProBook 440 G6 RAM Replacement, Battery: step 4, image 1 of 2 HP ProBook 440 G6 RAM Replacement, Battery: step 4, image 2 of 2
      • Using a Phillips #0 Screwdriver, remove the two 4mm Phillips screws that secure the battery to the computer.
      Ask FixBot
    2. HP ProBook 440 G6 RAM Replacement: step 5, image 1 of 1
      • Use a tool to push the tab back on the bottom left of the battery.
      Ask FixBot
    3. HP ProBook 440 G6 RAM Replacement: step 6, image 1 of 3 HP ProBook 440 G6 RAM Replacement: step 6, image 2 of 3 HP ProBook 440 G6 RAM Replacement: step 6, image 3 of 3
      • Lift the top of the battery.
      • Lift the battery out of the computer.
      Ask FixBot
    1. HP ProBook 440 G6 RAM Replacement, RAM: step 7, image 1 of 2 HP ProBook 440 G6 RAM Replacement, RAM: step 7, image 2 of 2
      • Carefully fold metallic sheet down to reveal the Ram.
      Ask FixBot
    2. HP ProBook 440 G6 RAM Replacement: step 8, image 1 of 2 HP ProBook 440 G6 RAM Replacement: step 8, image 2 of 2
      • Spread the retaining tabs on each side of the memory module slot to release the memory module.
      • The Ram should spring up on the end opposite the metallic sheet. If it doesn't, carefully pry up on the side opposite the metallic sheet.
      Ask FixBot
    3. HP ProBook 440 G6 RAM Replacement: step 9, image 1 of 3 HP ProBook 440 G6 RAM Replacement: step 9, image 2 of 3 HP ProBook 440 G6 RAM Replacement: step 9, image 3 of 3
      • Carefully pull the RAM at an angle to remove it from its connector.
      • Memory modules are designed with a notch to prevent incorrect insertion into the memory module slot.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Elijah Cain
397 Reputation
4 Guides authored
1 Guide Comment
Sehr gute Anleitung, vielen Dank
David - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 123
All Time: 497
