HP ProBook 440 G6 Lower Case Replacement
    1. HP ProBook 440 G6 Lower Case Replacement, Lower Case: step 1, image 1 of 3 HP ProBook 440 G6 Lower Case Replacement, Lower Case: step 1, image 2 of 3 HP ProBook 440 G6 Lower Case Replacement, Lower Case: step 1, image 3 of 3
      • Using a Phillips #0 Screwdriver, remove the two 5 mm screws on the front-facing side of the lower case.
      • Using a Phillips #0 Screwdriver, remove the remaining five 5 mm Phillips screws securing the lower case.
      • The two screws in the front of the backplate are of a differing size to the other five.
      Ask FixBot
    2. HP ProBook 440 G6 Lower Case Replacement: step 2, image 1 of 3 HP ProBook 440 G6 Lower Case Replacement: step 2, image 2 of 3 HP ProBook 440 G6 Lower Case Replacement: step 2, image 3 of 3
      • Starting under the display, carefully use a plastic prying tool (iFixit opening tool) to disengage the retaining clips.
      • You may hear soft clicking sounds as the clips come undone.
      • Once a corner or edge starts to lift, slowly slide the tool along the edge to loosen more of the bottom panel.
      • Keep working around the edges until all the clips are loose.
      Ask FixBot
    3. HP ProBook 440 G6 Lower Case Replacement: step 3, image 1 of 3 HP ProBook 440 G6 Lower Case Replacement: step 3, image 2 of 3 HP ProBook 440 G6 Lower Case Replacement: step 3, image 3 of 3
      • Gently lift the rear of the cover to disengage it from the computer.
      • Carefully remove the bottom cover from the computer.
      Ask FixBot
Elijah Cain
397 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 71
All Time: 210
