HP ProBook 440 G6 Fan Replacement
    1. HP ProBook 440 G6 Fan Replacement, Lower Case: step 1, image 1 of 3 HP ProBook 440 G6 Fan Replacement, Lower Case: step 1, image 2 of 3 HP ProBook 440 G6 Fan Replacement, Lower Case: step 1, image 3 of 3
      • Using a Phillips #0 Screwdriver, remove the two 5 mm screws on the front-facing side of the lower case.
      • Using a Phillips #0 Screwdriver, remove the remaining five 5 mm Phillips screws securing the lower case.
      • The two screws in the front of the backplate are of a differing size to the other five.
      Ask FixBot
    2. HP ProBook 440 G6 Fan Replacement: step 2, image 1 of 3 HP ProBook 440 G6 Fan Replacement: step 2, image 2 of 3 HP ProBook 440 G6 Fan Replacement: step 2, image 3 of 3
      • Starting under the display, carefully use a plastic prying tool (iFixit opening tool) to disengage the retaining clips.
      • You may hear soft clicking sounds as the clips come undone.
      • Once a corner or edge starts to lift, slowly slide the tool along the edge to loosen more of the bottom panel.
      • Keep working around the edges until all the clips are loose.
      Ask FixBot
    3. HP ProBook 440 G6 Fan Replacement: step 3, image 1 of 3 HP ProBook 440 G6 Fan Replacement: step 3, image 2 of 3 HP ProBook 440 G6 Fan Replacement: step 3, image 3 of 3
      • Gently lift the rear of the cover to disengage it from the computer.
      • Carefully remove the bottom cover from the computer.
      Ask FixBot
    1. HP ProBook 440 G6 Fan Replacement, Battery: step 4, image 1 of 2 HP ProBook 440 G6 Fan Replacement, Battery: step 4, image 2 of 2
      • Using a Phillips #0 Screwdriver, remove the two 4mm Phillips screws that secure the battery to the computer.
      Ask FixBot
    2. HP ProBook 440 G6 Fan Replacement: step 5, image 1 of 1
      • Use a tool to push the tab back on the bottom left of the battery.
      Ask FixBot
    3. HP ProBook 440 G6 Fan Replacement: step 6, image 1 of 3 HP ProBook 440 G6 Fan Replacement: step 6, image 2 of 3 HP ProBook 440 G6 Fan Replacement: step 6, image 3 of 3
      • Lift the top of the battery.
      • Lift the battery out of the computer.
      Ask FixBot
    1. HP ProBook 440 G6 Fan Replacement, Fan: step 7, image 1 of 1
      • Carefully disconnect the fan cable from the system board.
      Ask FixBot
    2. HP ProBook 440 G6 Fan Replacement: step 8, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two 4 mm-long Phillips screws that secure the fan to the chassis.
      Ask FixBot
    3. HP ProBook 440 G6 Fan Replacement: step 9, image 1 of 3 HP ProBook 440 G6 Fan Replacement: step 9, image 2 of 3 HP ProBook 440 G6 Fan Replacement: step 9, image 3 of 3
      • Lift the fan and remove it from the computer.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 72
All Time: 264
