HP ProBook 440 G6 Battery Replacement
    1. HP ProBook 440 G6 Battery Replacement, Lower Case: step 1, image 1 of 3 HP ProBook 440 G6 Battery Replacement, Lower Case: step 1, image 2 of 3 HP ProBook 440 G6 Battery Replacement, Lower Case: step 1, image 3 of 3
      • Using a Phillips #0 Screwdriver, remove the two 5 mm screws on the front-facing side of the lower case.
      • Using a Phillips #0 Screwdriver, remove the remaining five 5 mm Phillips screws securing the lower case.
      • The two screws in the front of the backplate are of a differing size to the other five.
      Ask FixBot
    2. HP ProBook 440 G6 Battery Replacement: step 2, image 1 of 3 HP ProBook 440 G6 Battery Replacement: step 2, image 2 of 3 HP ProBook 440 G6 Battery Replacement: step 2, image 3 of 3
      • Starting under the display, carefully use a plastic prying tool (iFixit opening tool) to disengage the retaining clips.
      • You may hear soft clicking sounds as the clips come undone.
      • Once a corner or edge starts to lift, slowly slide the tool along the edge to loosen more of the bottom panel.
      • Keep working around the edges until all the clips are loose.
      Ask FixBot
    3. HP ProBook 440 G6 Battery Replacement: step 3, image 1 of 3 HP ProBook 440 G6 Battery Replacement: step 3, image 2 of 3 HP ProBook 440 G6 Battery Replacement: step 3, image 3 of 3
      • Gently lift the rear of the cover to disengage it from the computer.
      • Carefully remove the bottom cover from the computer.
      Ask FixBot
    1. HP ProBook 440 G6 Battery Replacement, Battery: step 4, image 1 of 2 HP ProBook 440 G6 Battery Replacement, Battery: step 4, image 2 of 2
      • Using a Phillips #0 Screwdriver, remove the two 4mm Phillips screws that secure the battery to the computer.
      Ask FixBot
    2. HP ProBook 440 G6 Battery Replacement: step 5, image 1 of 1
      • Use a tool to push the tab back on the bottom left of the battery.
      Ask FixBot
    3. HP ProBook 440 G6 Battery Replacement: step 6, image 1 of 3 HP ProBook 440 G6 Battery Replacement: step 6, image 2 of 3 HP ProBook 440 G6 Battery Replacement: step 6, image 3 of 3
      • Lift the top of the battery.
      • Lift the battery out of the computer.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Elijah Cain
397 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 121
All Time: 385
