HP ProBook 4320t Wi-Fi Card Replacement Guide
    1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Battery Removal: step 1, image 1 of 2 HP ProBook 4320t Wi-Fi Card Replacement Guide, Battery Removal: step 1, image 2 of 2
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      Ask FixBot
    2. HP ProBook 4320t Wi-Fi Card Replacement Guide, Screws: step 2, image 1 of 2 HP ProBook 4320t Wi-Fi Card Replacement Guide, Screws: step 2, image 2 of 2
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      Ask FixBot
    3. HP ProBook 4320t Wi-Fi Card Replacement Guide, Flip: step 3, image 1 of 1
      • Flip laptop over and open it.
      Ask FixBot
    4. HP ProBook 4320t Wi-Fi Card Replacement Guide, Push N Lift: step 4, image 1 of 1
      • Slightly push up while lifting up on the power button panel to release the panel.
      Ask FixBot
    1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Unscrewing: step 5, image 1 of 1
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      Ask FixBot
    2. HP ProBook 4320t Wi-Fi Card Replacement Guide, Careful Now: step 6, image 1 of 2 HP ProBook 4320t Wi-Fi Card Replacement Guide, Careful Now: step 6, image 2 of 2
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      Ask FixBot
    3. HP ProBook 4320t Wi-Fi Card Replacement Guide, Disconnect Wire: step 7, image 1 of 1
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      Ask FixBot
    1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Unscrew: step 8, image 1 of 1
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
      Ask FixBot
    2. HP ProBook 4320t Wi-Fi Card Replacement Guide, Slide the Panel Off: step 9, image 1 of 1
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
      Ask FixBot
    3. HP ProBook 4320t Wi-Fi Card Replacement Guide, Lift up Carefully: step 10, image 1 of 1
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
      Ask FixBot
    4. HP ProBook 4320t Wi-Fi Card Replacement Guide, Disconnect Wire: step 11, image 1 of 1
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
      Ask FixBot
    1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Wi-Fi Card: step 12, image 1 of 1
      • Use black spudger to detach the two antenna cable connectors to the Wi-Fi card.
      • Be careful not to break the cords.
      Ask FixBot
    2. HP ProBook 4320t Wi-Fi Card Replacement Guide: step 13, image 1 of 1
      • Unscrew the two (2.5 mm Phillips) screws holding the wifi card in.
      • Be careful because upon the last turn of the screw, the Wi-Fi card lifts up slightly.
      Ask FixBot
    3. HP ProBook 4320t Wi-Fi Card Replacement Guide: step 14, image 1 of 1
      • Pull the Wi-Fi card towards the left to remove.
      Ask FixBot
Joshua
134 Reputation
6 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 102
All Time: 1,037
