Up to 20% off select tools
HP ProBook 4320t Touchpad Panel Replacement Guide
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
88
All Time:
912
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
Introduction
Go to step 1 ↓
Replacing the touch pad panel can seam challenging without the proper instructions. There are many components that need to be removed before the touch pad panel. The panel needs to be removed in order to access other components.
    1. HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: step 1, image 1 of 2 HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: step 1, image 2 of 2
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      Ask FixBot
    2. HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: step 2, image 1 of 2 HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: step 2, image 2 of 2
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      Ask FixBot
    3. HP ProBook 4320t Touchpad Panel Replacement Guide, Flip: step 3, image 1 of 1
      • Flip laptop over and open it.
      Ask FixBot
    4. HP ProBook 4320t Touchpad Panel Replacement Guide, Push N Lift: step 4, image 1 of 1
      • Slightly push up while lifting up on the power button panel to release the panel.
      Ask FixBot
    1. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrewing: step 5, image 1 of 1
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      Ask FixBot
    2. HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: step 6, image 1 of 2 HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: step 6, image 2 of 2
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      Ask FixBot
    3. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: step 7, image 1 of 1
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      Ask FixBot
    1. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrew: step 8, image 1 of 1
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
      Ask FixBot
    2. HP ProBook 4320t Touchpad Panel Replacement Guide, Slide the Panel Off: step 9, image 1 of 1
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
      Ask FixBot
    3. HP ProBook 4320t Touchpad Panel Replacement Guide, Lift up Carefully: step 10, image 1 of 1
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
      Ask FixBot
    4. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: step 11, image 1 of 1
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
      Ask FixBot
Author
with
Joshua
134 Reputation
6 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 88
All Time: 912
