HP ProBook 4320t Speakers Replacement Guide
    1. HP ProBook 4320t Speakers Replacement Guide, Battery Removal: step 1, image 1 of 2 HP ProBook 4320t Speakers Replacement Guide, Battery Removal: step 1, image 2 of 2
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      Ask FixBot
    2. HP ProBook 4320t Speakers Replacement Guide, Screws: step 2, image 1 of 2 HP ProBook 4320t Speakers Replacement Guide, Screws: step 2, image 2 of 2
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      Ask FixBot
    3. HP ProBook 4320t Speakers Replacement Guide, Flip: step 3, image 1 of 1
      • Flip laptop over and open it.
      Ask FixBot
    4. HP ProBook 4320t Speakers Replacement Guide, Push N Lift: step 4, image 1 of 1
      • Slightly push up while lifting up on the power button panel to release the panel.
      Ask FixBot
    1. HP ProBook 4320t Speakers Replacement Guide, Unscrewing: step 5, image 1 of 1
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      Ask FixBot
    2. HP ProBook 4320t Speakers Replacement Guide, Careful Now: step 6, image 1 of 2 HP ProBook 4320t Speakers Replacement Guide, Careful Now: step 6, image 2 of 2
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      Ask FixBot
    3. HP ProBook 4320t Speakers Replacement Guide, Disconnect Wire: step 7, image 1 of 1
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      Ask FixBot
    1. HP ProBook 4320t Speakers Replacement Guide, Speakers: step 8, image 1 of 1
      • Use the black spudger tool to lift the white, black, and red ribbon cable connector up so that it is disconnected.
      Ask FixBot
    2. HP ProBook 4320t Speakers Replacement Guide: step 9, image 1 of 1
      • Unscrew the two (2.5 mm Phillips) screws (located on the upper most part of the computer) holding the speakers in.
      Ask FixBot
    3. HP ProBook 4320t Speakers Replacement Guide: step 10, image 1 of 1
      • Using the black spudger tool, gently pry off the right speaker.
      • Be careful to not break the cord.
      Ask FixBot
    4. HP ProBook 4320t Speakers Replacement Guide: step 11, image 1 of 1
      • Remove the cords from the retention clips.
      Ask FixBot
    5. HP ProBook 4320t Speakers Replacement Guide: step 12, image 1 of 1
      • Remove the left speaker as completed in step #10.
      Ask FixBot
Eric Markham
227 Reputation
4 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 116
All Time: 921
