Up to 20% off select tools
HP ProBook 4320t RAM Replacement Guide
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
87
All Time:
1,823
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If your computer is running slowly or not downloading as quickly as you would like, replace the RAM card to an upgraded version.
    1. HP ProBook 4320t RAM Replacement Guide, Battery Removal: step 1, image 1 of 2 HP ProBook 4320t RAM Replacement Guide, Battery Removal: step 1, image 2 of 2
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      Ask FixBot
    2. HP ProBook 4320t RAM Replacement Guide, Screws: step 2, image 1 of 2 HP ProBook 4320t RAM Replacement Guide, Screws: step 2, image 2 of 2
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      Ask FixBot
    3. HP ProBook 4320t RAM Replacement Guide, Flip: step 3, image 1 of 1
      • Flip laptop over and open it.
      Ask FixBot
    4. HP ProBook 4320t RAM Replacement Guide, Push N Lift: step 4, image 1 of 1
      • Slightly push up while lifting up on the power button panel to release the panel.
      Ask FixBot
    1. HP ProBook 4320t RAM Replacement Guide, Unscrewing: step 5, image 1 of 1
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      Ask FixBot
    2. HP ProBook 4320t RAM Replacement Guide, Careful Now: step 6, image 1 of 2 HP ProBook 4320t RAM Replacement Guide, Careful Now: step 6, image 2 of 2
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      Ask FixBot
    3. HP ProBook 4320t RAM Replacement Guide, Disconnect Wire: step 7, image 1 of 1
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      Ask FixBot
    1. HP ProBook 4320t RAM Replacement Guide, RAM: step 8, image 1 of 1
      • Press the two prongs outward, and the RAM card will come out of PCI Express connector.
      Ask FixBot
5 other people completed this guide.
Author
with
Eric Markham
227 Reputation
4 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 87
All Time: 1,823
