HP ProBook 4320t Processor Heat Sink Replacement Guide
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: step 1, image 1 of 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: step 1, image 2 of 2
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      Ask FixBot
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: step 2, image 1 of 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: step 2, image 2 of 2
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      Ask FixBot
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Flip: step 3, image 1 of 1
      • Flip laptop over and open it.
      Ask FixBot
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Push N Lift: step 4, image 1 of 1
      • Slightly push up while lifting up on the power button panel to release the panel.
      Ask FixBot
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrewing: step 5, image 1 of 1
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      Ask FixBot
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: step 6, image 1 of 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: step 6, image 2 of 2
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      Ask FixBot
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: step 7, image 1 of 1
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      Ask FixBot
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrew: step 8, image 1 of 1
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
      Ask FixBot
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Slide the Panel Off: step 9, image 1 of 1
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
      Ask FixBot
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Lift up Carefully: step 10, image 1 of 1
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
      Ask FixBot
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: step 11, image 1 of 1
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
      Ask FixBot
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Computer Fan: step 12, image 1 of 1
      • Locate silver holding panel on the left side of the computer.
      Ask FixBot
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide: step 13, image 1 of 1
      • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
      • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
      Ask FixBot
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide: step 14, image 1 of 1
      • Remove holding panel and put aside.
      Ask FixBot
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide: step 15, image 1 of 1
      • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
      Ask FixBot
    5. HP ProBook 4320t Processor Heat Sink Replacement Guide: step 16, image 1 of 1
      • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
      Ask FixBot
    6. HP ProBook 4320t Processor Heat Sink Replacement Guide: step 17, image 1 of 1
      • Lift fan up carefully and replace.
      Ask FixBot
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Processor Heat Sink: step 18, image 1 of 1
      • Unscrew the four (2.5 mm Phillips) screws holding the processor heat sink in (located near the center of the laptop)
      Ask FixBot
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide: step 19, image 1 of 1
      • Lift slightly on the main component of the heat sink and slowly pull in towards the center (to your right) to free the heat sink.
      Ask FixBot
Eric Markham
227 Reputation
4 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 97
All Time: 1,568
