Up to 20% off select tools
HP ProBook 4320t Power Button Panel Replacement Guide
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
83
All Time:
1,138
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The power button panel is one of the easiest components to replace on th HP 4320t. It may need replaceing, if damaged, to insure proper working order.
    1. HP ProBook 4320t Power Button Panel Replacement Guide, Battery Removal: step 1, image 1 of 2 HP ProBook 4320t Power Button Panel Replacement Guide, Battery Removal: step 1, image 2 of 2
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      Ask FixBot
    2. HP ProBook 4320t Power Button Panel Replacement Guide, Screws: step 2, image 1 of 2 HP ProBook 4320t Power Button Panel Replacement Guide, Screws: step 2, image 2 of 2
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      Ask FixBot
    3. HP ProBook 4320t Power Button Panel Replacement Guide, Flip: step 3, image 1 of 1
      • Flip laptop over and open it.
      Ask FixBot
    4. HP ProBook 4320t Power Button Panel Replacement Guide, Push N Lift: step 4, image 1 of 1
      • Slightly push up while lifting up on the power button panel to release the panel.
      Ask FixBot
3 other people completed this guide.
Author
with
Joshua
134 Reputation
6 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 83
All Time: 1,138
