Up to 20% off select tools
HP ProBook 4320t Computer Fan Replacement Guide
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
84
All Time:
1,802
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If your computer is always over heating due to the fan not properly cooling down the internal components, then you may need to replace the fan. The fan allows for air circulation throughout the computer.
    1. HP ProBook 4320t Computer Fan Replacement Guide, Computer Fan: step 1, image 1 of 1
      • Locate silver holding panel on the left side of the computer.
      Ask FixBot
    2. HP ProBook 4320t Computer Fan Replacement Guide: step 2, image 1 of 1
      • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
      • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
      Ask FixBot
    3. HP ProBook 4320t Computer Fan Replacement Guide: step 3, image 1 of 1
      • Remove holding panel and put aside.
      Ask FixBot
    4. HP ProBook 4320t Computer Fan Replacement Guide: step 4, image 1 of 1
      • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
      Ask FixBot
    5. HP ProBook 4320t Computer Fan Replacement Guide: step 5, image 1 of 1
      • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
      Ask FixBot
    6. HP ProBook 4320t Computer Fan Replacement Guide: step 6, image 1 of 1
      • Lift fan up carefully and replace.
      Ask FixBot
3 other people completed this guide.
Author
with
Eric Markham
227 Reputation
4 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 84
All Time: 1,802
