Up to 20% off select tools
HP ProBook 4320t Clock Battery Replacement Guide
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
98
All Time:
1,744
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
Introduction
Go to step 1 ↓
The clock battery is nessary for the internal clock to maintain the correct time. If the battery is dead, and you are not connected to the internet, your computer clock will be misleading.
    1. HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: step 1, image 1 of 2 HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: step 1, image 2 of 2
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      Ask FixBot
    2. HP ProBook 4320t Clock Battery Replacement Guide, Screws: step 2, image 1 of 2 HP ProBook 4320t Clock Battery Replacement Guide, Screws: step 2, image 2 of 2
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      Ask FixBot
    3. HP ProBook 4320t Clock Battery Replacement Guide, Flip: step 3, image 1 of 1
      • Flip laptop over and open it.
      Ask FixBot
    4. HP ProBook 4320t Clock Battery Replacement Guide, Push N Lift: step 4, image 1 of 1
      • Slightly push up while lifting up on the power button panel to release the panel.
      Ask FixBot
    1. HP ProBook 4320t Clock Battery Replacement Guide, Unscrewing: step 5, image 1 of 1
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      Ask FixBot
    2. HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: step 6, image 1 of 2 HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: step 6, image 2 of 2
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      Ask FixBot
    3. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: step 7, image 1 of 1
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      Ask FixBot
    1. HP ProBook 4320t Clock Battery Replacement Guide, Unscrew: step 8, image 1 of 1
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
      Ask FixBot
    2. HP ProBook 4320t Clock Battery Replacement Guide, Slide the Panel Off: step 9, image 1 of 1
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
      Ask FixBot
    3. HP ProBook 4320t Clock Battery Replacement Guide, Lift up Carefully: step 10, image 1 of 1
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
      Ask FixBot
    4. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: step 11, image 1 of 1
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
      Ask FixBot
    1. HP ProBook 4320t Clock Battery Replacement Guide, Detach Cables: step 12, image 1 of 1
      • Using the black spudger, detach the two antenna cable connectors leading to the Wi-Fi card (this is to access the clock battery without causing damage to the cords).
      Ask FixBot
    2. HP ProBook 4320t Clock Battery Replacement Guide, Pop it Out: step 13, image 1 of 1
      • Using your black spudger, gently press down and towards you until the battery slides out.
      Ask FixBot
      • Put new clock battery in and reassemble.
      Ask FixBot
2 other people completed this guide.
Author
with
Joshua
134 Reputation
6 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 98
All Time: 1,744
