Up to 20% off select tools
HP ProBook 430 G6 Memory Upgrade
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
76
All Time:
517
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Tools
    1. HP ProBook 430 G6 Memory Upgrade, Remove the screws from the base: step 1, image 1 of 1
      • Turn off the laptop and remove power cable.
      • Flip the laptop upside down.
      • Remove the labeled screws with Phillips #0 screwdriver.
      Ask FixBot
    2. HP ProBook 430 G6 Memory Upgrade, Remove the base: step 2, image 1 of 1
      • Remove the metal base with iFixit Opening Tool or Opening Picks.
      Ask FixBot
    3. HP ProBook 430 G6 Memory Upgrade, Disconnect the battery: step 3, image 1 of 1
      • Disconnect the battery by removing the labeled screws and lifting the battery upwards from the box-labeled connector.
      • Battery disconnecting is very important to do before any replacements!
      Ask FixBot
    1. HP ProBook 430 G6 Memory Upgrade, Upgrade the memory: step 4, image 1 of 1
      • Remove the old memory slot by moving labeled holders on the both sides of the slot.
      • Insert the new memory slot by set its side against the box-labeled interface and plug it by pressing it down.
      • You can too set a slot to the second place.
      Ask FixBot
If you want to upgrade memory on HP ProBook 430 G6, this guide is for you!
Author
with
[deleted]
593 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 76
All Time: 517
