HP ProBook 430 G6 M.2 Hard Drive Upgrade
    1. HP ProBook 430 G6 M.2 Hard Drive Upgrade, Remove the screws from the base: step 1, image 1 of 1
      • Turn off the laptop and remove power cable.
      • Flip the laptop upside down.
      • Remove the labeled screws with Phillips #0 screwdriver.
      Ask FixBot
    2. HP ProBook 430 G6 M.2 Hard Drive Upgrade, Remove the base: step 2, image 1 of 1
      • Remove the metal base with iFixit Opening Tool or Opening Picks.
      Ask FixBot
    3. HP ProBook 430 G6 M.2 Hard Drive Upgrade, Disconnect the battery: step 3, image 1 of 1
      • Disconnect the battery by removing the labeled screws and lifting the battery upwards from the box-labeled connector.
      • Battery disconnecting is very important to do before any replacements!
      Ask FixBot
    1. HP ProBook 430 G6 M.2 Hard Drive Upgrade, Upgrade the M.2 hard drive: step 4, image 1 of 1
      • Remove the old M.2 hard drive by removing the labeled screw.
      • Insert a new M.2 hard drive by mounting the labeled screw.
      • Remember, that the laptop supports only M.2 SATA SSD hard drives, not M.2 NVMe SSD.
      Ask FixBot
Finish Line
Hiiri522
593 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 34
All Time: 216
