HP Prime Graphing Calculator G8X92A Button Panel Replacement
  1. Careful: steps 1-3 are sourced from a guide that's marked as in-progress.
    HP Prime Graphing Calculator G8X92A Button Panel Replacement, Prerequisites: step 1, image 1 of 1
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
    Ask FixBot
  2. HP Prime Graphing Calculator G8X92A Button Panel Replacement, Disassembly: step 2, image 1 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Disassembly: step 2, image 2 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Disassembly: step 2, image 3 of 3
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
    Ask FixBot
  3. HP Prime Graphing Calculator G8X92A Button Panel Replacement, Replacement: step 3, image 1 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Replacement: step 3, image 2 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Replacement: step 3, image 3 of 3
    • Remove the battery.
    Ask FixBot
  4. HP Prime Graphing Calculator G8X92A Button Panel Replacement, Button Panel: step 4, image 1 of 2 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Button Panel: step 4, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the four 4.5 mm screws securing the back panel to the device.
    Ask FixBot
  5. HP Prime Graphing Calculator G8X92A Button Panel Replacement: step 5, image 1 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: step 5, image 2 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: step 5, image 3 of 3
    • Using a spudger, gently pry apart the front and back panels.
    Ask FixBot
  6. HP Prime Graphing Calculator G8X92A Button Panel Replacement: step 6, image 1 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: step 6, image 2 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Using a Phillips #00 screwdriver, remove the eleven 3 mm screws securing the battery board/button panel located at the bottom half of the device.
    • Using a plastic opening tool, gently pry the retaining clip securing the ribbon cable to the top-left side of the board.
    • Using plastic tweezers, gently unplug the ribbon cable from the board.
    Ask FixBot
  7. HP Prime Graphing Calculator G8X92A Button Panel Replacement: step 7, image 1 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: step 7, image 2 of 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: step 7, image 3 of 3
    • Using a plastic opening tool, gently pry upward on the battery board/button panel from the bottom to remove.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 26
All Time: 2,044
