Introduction
Go to step 1 ↓If your HP Photosmart C3180 printer keeps producing scans that result in streaks, smudging, lines that are not cleanable, or if your scanner's glass is cracked, you're in need of a replacement. If the glass is damaged the quality of all scanned and copied documents is going to be significantly worse. The following guide gives detailed instructions on how to remove a damaged scanner glass, and replace it with a new one. Thus, restoring full functionality to your printer. Please make sure that your printer is unplugged before beginning any repairs!
Tools
Spudger4.9
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the printer body.
Unscrew the T10 12 mm Torx screw.
Remove the plastic tab holding the glass in place.
To reassemble your device after replacing the glass, follow these instructions starting from the removal of the top panel in reverse order.
2 other people completed this guide.
1 Guide Comment
If I hadn't already taken mine all the way apart to clean it up good this is all I needed to do to start off with. Good direction step by step. Thanks
