HP Photosmart c3180 Scanner Bulb Replacement
Views: 7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
91
All Time:
7,006
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the scanner on your HP Photosmart c3180 is not working, you may want to check the scanner bulb.
The scanner bulb illuminates the document being scanned in order for the printer to get a clearer image of the document.
Scanner bulbs dim over time and eventually burn out. This requires the owner to replace the bulb in order to get the scanner working again.
This guide requires steady hands to deal with small parts as well as knowing the parts of the printer.
BEFORE REPLACING BULB UNPLUG PRINTER FROM POWER SOURCE
Tools
    1. HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: step 1, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: step 1, image 2 of 2
      • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
      • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
      • Remove the two T10 12mm Torx screws from the left side panel.
      Ask FixBot
    2. HP Photosmart c3180 Scanner Bulb Replacement: step 2, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement: step 2, image 2 of 2
      • Firmly pull the the back of the side panel until it separates from the body of the printer.
      • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
      Ask FixBot
    3. HP Photosmart c3180 Scanner Bulb Replacement: step 3, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement: step 3, image 2 of 2
      • Rotate the printer 90 degrees clockwise.
      • Grasp the paper tray and rotate it down.
      • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
      Ask FixBot
    4. HP Photosmart c3180 Scanner Bulb Replacement: step 4, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement: step 4, image 2 of 2
      • Remove the two T10 12 mm Torx screws.
      • Grasp both sides of the side panel and pull it forward to remove the panel.
      Ask FixBot
    5. HP Photosmart c3180 Scanner Bulb Replacement: step 5, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement: step 5, image 2 of 2
      • Rotate the printer 90 degrees counter clockwise.
      • Lift the scanner lid to expose the scanner glass.
      Ask FixBot
    6. HP Photosmart c3180 Scanner Bulb Replacement: step 6, image 1 of 1
      • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
      Ask FixBot
    7. HP Photosmart c3180 Scanner Bulb Replacement: step 7, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement: step 7, image 2 of 2
      • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
      • Remove the front panel by grasping its front and pulling away from the printer.
      Ask FixBot
    8. HP Photosmart c3180 Scanner Bulb Replacement: step 8, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement: step 8, image 2 of 2
      • Remove the cable connecting the top panel of the printer to the power button assembly.
      Ask FixBot
    9. HP Photosmart c3180 Scanner Bulb Replacement: step 9, image 1 of 1
      • Carefully lift the top panel of the printer away from the printer body.
      Ask FixBot
    1. HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: step 10, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: step 10, image 2 of 2
      • Set aside the top panel of the printer.
      • Lift the scanner carriage vertically, being careful not to yank of the cables connecting it to the printer.
      Ask FixBot
    2. HP Photosmart c3180 Scanner Bulb Replacement: step 11, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement: step 11, image 2 of 2
      • Flip the scanner carriage over to expose the connectors on the bottom.
      • Carefully remove the small cable from the connector.
      • Carefully remove the large cable from the connector.
      Ask FixBot
    3. HP Photosmart c3180 Scanner Bulb Replacement: step 12, image 1 of 2 HP Photosmart c3180 Scanner Bulb Replacement: step 12, image 2 of 2
      • Remove the scanner carriage from the scanner tray and flip it upside down.
      • Remove the two T10 12mm Torx screws.
      • Remove the scanner carriage from the scanner bulb.
      Ask FixBot
2 other people completed this guide.
Jim
1,638 Reputation
10 Guides authored
Cal Poly, Team 20-30, Maness Fall 2011 Member of Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 Members
120 Guides authored
1 Guide Comment
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
ddaviddierlam - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 91
All Time: 7,006
