HP Photosmart Premium C309g Scanner Replacement
  1. HP Photosmart Premium C309g Scanner Replacement, Scanner: step 1, image 1 of 1
    • Open the top of the printer. The printer should appear as shown.
    Ask FixBot
  2. HP Photosmart Premium C309g Scanner Replacement: step 2, image 1 of 2 HP Photosmart Premium C309g Scanner Replacement: step 2, image 2 of 2
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
    Ask FixBot
  3. HP Photosmart Premium C309g Scanner Replacement: step 3, image 1 of 2 HP Photosmart Premium C309g Scanner Replacement: step 3, image 2 of 2
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
    Ask FixBot
  4. HP Photosmart Premium C309g Scanner Replacement: step 4, image 1 of 1
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
    Ask FixBot
  5. HP Photosmart Premium C309g Scanner Replacement: step 5, image 1 of 1
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
    Ask FixBot
  6. HP Photosmart Premium C309g Scanner Replacement: step 6, image 1 of 1
    • Lift the scanner glass piece from the printer and set it aside.
    Ask FixBot
  7. HP Photosmart Premium C309g Scanner Replacement: step 7, image 1 of 2 HP Photosmart Premium C309g Scanner Replacement: step 7, image 2 of 2
    • Gently pick up the scanner piece as shown to see the bottom side and wiring.
    Ask FixBot
  8. HP Photosmart Premium C309g Scanner Replacement: step 8, image 1 of 2 HP Photosmart Premium C309g Scanner Replacement: step 8, image 2 of 2
    • Gently remove the 2 wire ribbons shown by pulling them away from the scanner piece.
    Ask FixBot
2 other people completed this guide.
Charles
401 Reputation
2 Guides authored
Michigan Tech, Team 1-2, Lauer Fall 2014 Member of Michigan Tech, Team 1-2, Lauer Fall 2014
MTU-LAUER-F14S1G2
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,689
