HP Photosmart 5520 Maintenance
  1. HP Photosmart 5520 Maintenance, Centering the printhead: step 1, image 1 of 2 HP Photosmart 5520 Maintenance, Centering the printhead: step 1, image 2 of 2
    • Turn on the printer
    • Lift up the scanner glass and the top cover, then the printerhead is centered in the printer case
    • Remove the ink cartridges.
    • Unplug the printer but do not turn off with the front I/O button. Otherwise the printhead will return to its park slot.
    • Use adhesive tape to fix together the scanner glass and the cover
    Ask FixBot
  2. HP Photosmart 5520 Maintenance, Removing the top cover: step 2, image 1 of 2 HP Photosmart 5520 Maintenance, Removing the top cover: step 2, image 2 of 2
    • Gently pull on the hook. Retain the scanner glass and the cover once the hook is removed.
    Ask FixBot
  3. HP Photosmart 5520 Maintenance, Removing the printer hood: step 3, image 1 of 3 HP Photosmart 5520 Maintenance, Removing the printer hood: step 3, image 2 of 3 HP Photosmart 5520 Maintenance, Removing the printer hood: step 3, image 3 of 3
    • Unscrew the 7 torx screws. Do not forget the one under the printer label (You have to remove the printer label. Lower right corner).
    • Push the clips at the rear of the LCD panel and pull the LCD panel outwards at the same time. The clips can be felt, but not seen underneath the plastic on which the HP label is visible in the middle picture. A fourth picture would help here.
    • Then, pull the ribbon connected to the LCD panel to disconnect the LCD panel from the printer.
    • Remove the 2 remaining torx screws hidden by the LCD panel
    • See where are clips (Blue arrows)
    Ask FixBot
    • Now the cover can be removed and expose the inner workings of the printer.
    Ask FixBot
  4. HP Photosmart 5520 Maintenance, Removing the print head: step 5, image 1 of 3 HP Photosmart 5520 Maintenance, Removing the print head: step 5, image 2 of 3 HP Photosmart 5520 Maintenance, Removing the print head: step 5, image 3 of 3
    • Remove the springs that maintain the print head.
    • Remove the print head by pulling on the ribbons. These are delicate and easily damaged if attempting to clean with alcohol.
    • In case you want to replace the print head, the spare part reference is: CN688A
    • When inserting the print head after cleaning or replacing, make sure the horizontal plastic ribbon is between the plastic guides, as shown in the last picture. Getting this wrong may cause the print head to jam when you put the power back on at the end.
    Ask FixBot
  5. HP Photosmart 5520 Maintenance, Cleaning the print head park slot: step 6, image 1 of 3 HP Photosmart 5520 Maintenance, Cleaning the print head park slot: step 6, image 2 of 3 HP Photosmart 5520 Maintenance, Cleaning the print head park slot: step 6, image 3 of 3
    • The printer has an automatic feature to clean the print head. Usually, there is a lot of ink (Probably melt with dust) in the area where the print head is cleaned
    • Remove 4 of the 5 torx screws as shown in the picture. As given in a user comment, the top right one serves to join the two pieces of this part.
    • Assuming the print head is now removed (Not shown on the picture), now gently tip the plastic plate and remove it
    • If you didn't put gloves yet, it is time to do it !
    • Now, push the carriage that holds the print head cleaning system (Red arrows)
    • The carriage that holds the print head cleaning system is now clean (Last picture)
    Ask FixBot
71 other people completed this guide.
DrNox
1,996 Reputation
2 Guides authored
45 Guide Comments
A l'étape 3, je n'arrive pas à retirer l'écran LCD. quand on me dit de pousser les deux clips à l'arrière, je ne vois les pas. tout semble solide et j'ai peur de casser quelque chose en forçant. comment franchir cette étape?
Joeblues - Reply Share
J'ai aussi eu un peu de difficulté à enlever l'écran LCD. Il ne faut pas hésiter à tirer dessus. Quand un clip est enlevé, les autres viennent plus facilement
LENNON - Reply Share
Bonjour : très bon tutoriel, mais ..., manquent des précisions ; Etape 2 : comment est fixée et se démonte cette charnière-glissière ? Etape 3 : MISSION IMPOSSIBLE pour le démontage de l'écran LCD ! combien de clips ? à quoi ressemblent-ils ? comment faut-il agir sur ces clips, "à tâtons et en aveugle" ? etc ... ; je n'ai pas réussi à franchir cette étape qui demande des explications supplémentaires ... Merci : MJL
MJL - Reply Share
J'ai étais ravie d'avoir ce tutoriel entre les mains car j'avais de gros problèmes et la tout est très bien détaillé en image c'est parfait même les références pour les pièces à changer d'indiquer c'est très bien
quentinseguela - Reply Share
The print head cleaning system carriage can be completely removed. Need to push the carriage to back of printer. Remove screw in back right corner, next to the black cylindrical pump with rubber hoses, and another in the gear assembly that runs this pump. Then wiggle and remove this pump/gear assembly. Now the carriage can be moved forward on the track till a slot allows getting past a small metal shaft and a gear. Now you can clean it in the sink with hot water. Be careful to put the two springs back on this carriage before putting it back into the printer.
And be sure all the tubing will freely flow water, or the pumping action will not work!
John Taft - Reply Share
Past 24 Hours: 8
Past 7 Days: 60
Past 30 Days: 286
All Time: 163,262
