Introduction
To detach the memory you will need a Phillips PH1 screwdriver. Also remember to be gentle with the screws because not all of them will completely detach from the plastic.
Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
Slide cover toward empty battery area and remove it.
