HP Pavillion G7-2235DX Keyboard Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
Past 7 Days:
25
Past 30 Days:
143
All Time:
4,883
Comments: 0
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
    1. HP Pavillion G7-2235DX Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Before beginning, make sure the computer is turned off and the charger is disconnected.
      • Flip the computer over, so that the bottom is facing up.
      Ask FixBot
    2. HP Pavillion G7-2235DX Keyboard Replacement: step 2, image 1 of 1
      • To remove the battery, slide the battery switch to the left.
      Ask FixBot
    3. HP Pavillion G7-2235DX Keyboard Replacement: step 3, image 1 of 2 HP Pavillion G7-2235DX Keyboard Replacement: step 3, image 2 of 2
      • Using a PH Screwdriver, remove the three 7.25mm screws located on the bottom panel.
      • After removing all screws, remove the panel by sliding down.
      Ask FixBot
    4. HP Pavillion G7-2235DX Keyboard Replacement: step 4, image 1 of 1
      • Using a PH screwdriver, remove the screw adjacent to the white labels.
      • There is a keyboard icon next to the screw
      Ask FixBot
    5. HP Pavillion G7-2235DX Keyboard Replacement: step 5, image 1 of 1
      • Flip the laptop over, and open it.
      Ask FixBot
    6. HP Pavillion G7-2235DX Keyboard Replacement: step 6, image 1 of 1
      • Using a plastic spudger, pry beneath the keyboard near the "delete" key, and pop the keyboard up from the laptop.
      • From the open gap, continue to pry around the perimeter of the keyboard, separating it from the laptop.
      Ask FixBot
    7. HP Pavillion G7-2235DX Keyboard Replacement: step 7, image 1 of 2 HP Pavillion G7-2235DX Keyboard Replacement: step 7, image 2 of 2
      • Using both hands, carefully lift the keyboard off of the laptop.
      • There may be a ribbon attached. If so, gently pull the ribbon cable up and away from the connector.
      Ask FixBot
8 other people completed this guide.
Bre'Anna Sanders
166 Reputation
2 Guides authored
USF Tampa, Team 1-7, Leahy Fall 2016 Member of USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 143
All Time: 4,883
