HP Pavillion G60-120US Disc Drive Replacement
    1. HP Pavillion G60-120US Disc Drive Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is turned off.
      • Turn the laptop over to reveal the battery.
      Ask FixBot
    2. HP Pavillion G60-120US Disc Drive Replacement: step 2, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement: step 2, image 2 of 2
      • Slide and hold the battery release switch to the left to release the battery from the device.
      Ask FixBot
    3. HP Pavillion G60-120US Disc Drive Replacement: step 3, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement: step 3, image 2 of 2
      • While holding the battery release switch, grab the battery and pull it upward gently.
      Ask FixBot
    1. HP Pavillion G60-120US Disc Drive Replacement, Keyboard: step 4, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the seven 4.0mm screws on the battery compartment of the laptop.
      Ask FixBot
    2. HP Pavillion G60-120US Disc Drive Replacement: step 5, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement: step 5, image 2 of 2
      • Using the Phillips #0 screwdriver, remove two 4.0mm screws from the hard disk cover.
      • Remove the hard disk cover.
      Ask FixBot
    3. HP Pavillion G60-120US Disc Drive Replacement: step 6, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement: step 6, image 2 of 2
      • Remove the hard drive by pulling gently and disconnecting the hard drive from the laptop.
      • Gently pull on the black and red wiring on the bottom left to separate the wire from the component.
      Ask FixBot
    4. HP Pavillion G60-120US Disc Drive Replacement: step 7, image 1 of 1
      • Remove the two 4.0 mm Phillips #0 screws from the hard disk compartment.
      Ask FixBot
    5. HP Pavillion G60-120US Disc Drive Replacement: step 8, image 1 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 8, image 2 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 8, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the two 4.0 mm screws from the memory card cover.
      • Remove the memory disk cover.
      Ask FixBot
    6. HP Pavillion G60-120US Disc Drive Replacement: step 9, image 1 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 9, image 2 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 9, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the 4.0 mm screw from the Wi-Fi chip cover.
      • Remove the Wi-Fi chip cover.
      Ask FixBot
    7. HP Pavillion G60-120US Disc Drive Replacement: step 10, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement: step 10, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the two 3.0 mm screws securing the Wi-Fi chip in place.
      • Grab the Wi-Fi chip and pull up gently to the left to disconnect it from the laptop.
      Ask FixBot
    8. HP Pavillion G60-120US Disc Drive Replacement: step 11, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement: step 11, image 2 of 2
      • Disconnect the two wires connecting the chip's base.
      • Remove the Wi-Fi chip.
      Ask FixBot
    9. HP Pavillion G60-120US Disc Drive Replacement: step 12, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the seven 4.0 mm screws on the bottom of the laptop.
      Ask FixBot
    10. HP Pavillion G60-120US Disc Drive Replacement: step 13, image 1 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 13, image 2 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 13, image 3 of 3
      • Turn the laptop back to its upright state.
      • Insert an opening tool into the upper right corner of the keyboard and gently lift it to separate it from the laptop.
      • Be sure not to apply excessive pressure to prevent the bending and breaking of the keyboard.
      • Do not pull the keyboard all the way out because there is a wiring connection under the keyboard.
      Ask FixBot
    11. HP Pavillion G60-120US Disc Drive Replacement: step 14, image 1 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 14, image 2 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 14, image 3 of 3
      • Grab the wiring and gently pull it out to disconnect it from the laptop.
      • Don't use excessive force.
      • Remove the keyboard.
      Ask FixBot
    1. HP Pavillion G60-120US Disc Drive Replacement, Display Assembly: step 15, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement, Display Assembly: step 15, image 2 of 2
      • Insert an opening tool into the top right side of the corner, and gently lift the rest of the cover to separate if from the laptop.
      • Avoid using excessive force which may break the cover.
      • Do not completely pull out the cover; there is a wire still attached to the laptop.
      Ask FixBot
    2. HP Pavillion G60-120US Disc Drive Replacement: step 16, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement: step 16, image 2 of 2
      • Using your fingertips, detach the ribbon cable by gently lifting up the black tab located on the bottom end of the cable.
      • Separate the cable and remove the cover.
      Ask FixBot
    3. HP Pavillion G60-120US Disc Drive Replacement: step 17, image 1 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 17, image 2 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 17, image 3 of 3
      • Remove the mouse and touchpad cable by lifting the black tab and gently pulling the cable out.
      Ask FixBot
    4. HP Pavillion G60-120US Disc Drive Replacement: step 18, image 1 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 18, image 2 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 18, image 3 of 3
      • Detach the white screen wiring on the bottom left side by gently pulling out.
      • Detach two black screen cables on the middle left side by gently pulling out the cables.
      • Pull out the black cable on the upper right side of the laptop.
      • Use gentle pressure while removing the wires.
      Ask FixBot
    5. HP Pavillion G60-120US Disc Drive Replacement: step 19, image 1 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 19, image 2 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 19, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the four 4.0 mm screws on both hinges of the laptop's screen.
      Ask FixBot
    6. HP Pavillion G60-120US Disc Drive Replacement: step 20, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement: step 20, image 2 of 2
      • Gently lift and detach the display assembly from the laptop’s base.
      Ask FixBot
    1. HP Pavillion G60-120US Disc Drive Replacement, Midframe: step 21, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the four 4mm screws from the midframe.
      Ask FixBot
    2. HP Pavillion G60-120US Disc Drive Replacement: step 22, image 1 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 22, image 2 of 3 HP Pavillion G60-120US Disc Drive Replacement: step 22, image 3 of 3
      • Using an opening tool, gently lift each corner of the midframe.
      • Use caution when applying pressure with the opening tool as it may break while attempting to lift the midframe.
      • Detach and remove the midframe from the main body of the laptop.
      Ask FixBot
    1. HP Pavillion G60-120US Disc Drive Replacement, Disc Drive: step 23, image 1 of 2 HP Pavillion G60-120US Disc Drive Replacement, Disc Drive: step 23, image 2 of 2
      • Detach the disc drive from the motherboard by gently pushing it to the right.
      • Remove the disc drive from the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 429
