HP Pavilion ze5000 Keyboard Replacement
    1. HP Pavilion ze5000 Keyboard Replacement, Keyboard: step 1, image 1 of 3 HP Pavilion ze5000 Keyboard Replacement, Keyboard: step 1, image 2 of 3 HP Pavilion ze5000 Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Remove the two 5mm Phillips #0 screws from the hinges
      Ask FixBot
    2. HP Pavilion ze5000 Keyboard Replacement: step 2, image 1 of 2 HP Pavilion ze5000 Keyboard Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Open the device as if you were going to use the device. Using Tweezers, pry the hinges from underneath the screen
      • Not much force is needed to pull the hinges off once the tweezers are properly positioned
      Ask FixBot
    3. HP Pavilion ze5000 Keyboard Replacement: step 3, image 1 of 2 HP Pavilion ze5000 Keyboard Replacement: step 3, image 2 of 2
      • Remove the wire connection by gently pulling on the fuse and connection itself.
      • Do not pull on the wires, as this can remove the wires from the connection, destroying the fuse.
      Ask FixBot
    4. HP Pavilion ze5000 Keyboard Replacement: step 4, image 1 of 3 HP Pavilion ze5000 Keyboard Replacement: step 4, image 2 of 3 HP Pavilion ze5000 Keyboard Replacement: step 4, image 3 of 3
      • Remove the four 4.0 mm Phillips #0 connecting the keyboard to the frame
      Ask FixBot
    5. HP Pavilion ze5000 Keyboard Replacement: step 5, image 1 of 2 HP Pavilion ze5000 Keyboard Replacement: step 5, image 2 of 2
      • Gently lift the keyboard up from the frame so that you can see the ribbon still connected.
      Ask FixBot
    6. HP Pavilion ze5000 Keyboard Replacement: step 6, image 1 of 3 HP Pavilion ze5000 Keyboard Replacement: step 6, image 2 of 3 HP Pavilion ze5000 Keyboard Replacement: step 6, image 3 of 3
      • Remove the ribbon by gently pulling up the ends of the white receiver it is inserted in to.
      • You may need to use tweezers for this part.
      • During reassembly, when inserting the ribbon, you will hear a quiet, clicking sound when pushing down on the ends of the receiver. Hearing this ensures the ribbon is in place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order starting at step 5.
Eric Beaudry
823 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 66
All Time: 574
