HP Pavilion x360 m3-u001dx System Board Replacement
    1. HP Pavilion x360 m3-u001dx System Board Replacement, Keyboard: step 1, image 1 of 1
      • Shut down the computer.
      • Disconnect the power and all external devices connected to the computer.
      • Working on your device while it is turned on may result in electric shock.
      Ask FixBot
    2. HP Pavilion x360 m3-u001dx System Board Replacement: step 2, image 1 of 2 HP Pavilion x360 m3-u001dx System Board Replacement: step 2, image 2 of 2
      • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
      Ask FixBot
    3. HP Pavilion x360 m3-u001dx System Board Replacement: step 3, image 1 of 1
      • Remove all of the screws located on the bottom of the laptop:
      • 5 Phillips 2.4 x 5.7 mm screws
      • 5 Phillips 2.0 x 5.0 mm screws
      • Make special note of each screw and screw lock size and location during removal and replacement.
      Ask FixBot
    4. HP Pavilion x360 m3-u001dx System Board Replacement: step 4, image 1 of 1
      • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
      Ask FixBot
    5. HP Pavilion x360 m3-u001dx System Board Replacement: step 5, image 1 of 2 HP Pavilion x360 m3-u001dx System Board Replacement: step 5, image 2 of 2
      • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
      • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
      Ask FixBot
    6. HP Pavilion x360 m3-u001dx System Board Replacement: step 6, image 1 of 1
      • Raise the keyboard slightly to access the touch pad and keyboard cables.
      • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
      Ask FixBot
    7. HP Pavilion x360 m3-u001dx System Board Replacement: step 7, image 1 of 1
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
      • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
      • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
      Ask FixBot
    8. HP Pavilion x360 m3-u001dx System Board Replacement: step 8, image 1 of 1
      • Lift the keyboard away from the base of the laptop.
      Ask FixBot
    1. HP Pavilion x360 m3-u001dx System Board Replacement, Battery: step 9, image 1 of 1
      • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
      Ask FixBot
    2. HP Pavilion x360 m3-u001dx System Board Replacement: step 10, image 1 of 1
      • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
      Ask FixBot
    1. HP Pavilion x360 m3-u001dx System Board Replacement, USB Port Shield: step 11, image 1 of 3 HP Pavilion x360 m3-u001dx System Board Replacement, USB Port Shield: step 11, image 2 of 3 HP Pavilion x360 m3-u001dx System Board Replacement, USB Port Shield: step 11, image 3 of 3
      • (You don't NEED to remove this shielding as you can remove the board with it still there.)
      • Remove the adhesive strip.
      • Lift the shield away from the base of the laptop.
      Ask FixBot
    1. HP Pavilion x360 m3-u001dx System Board Replacement, System Board (Motherboard): step 12, image 1 of 3 HP Pavilion x360 m3-u001dx System Board Replacement, System Board (Motherboard): step 12, image 2 of 3 HP Pavilion x360 m3-u001dx System Board Replacement, System Board (Motherboard): step 12, image 3 of 3
      Heavy-Duty Spudger
      Buy
      • Disconnect the ribbon cables attached to the system board (motherboard).
      • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
      Ask FixBot
    2. HP Pavilion x360 m3-u001dx System Board Replacement: step 13, image 1 of 2 HP Pavilion x360 m3-u001dx System Board Replacement: step 13, image 2 of 2
      • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
      Ask FixBot
    3. HP Pavilion x360 m3-u001dx System Board Replacement: step 14, image 1 of 2 HP Pavilion x360 m3-u001dx System Board Replacement: step 14, image 2 of 2
      • Pull the clipped cables from system board (motherboard).
      Ask FixBot
    4. HP Pavilion x360 m3-u001dx System Board Replacement: step 15, image 1 of 3 HP Pavilion x360 m3-u001dx System Board Replacement: step 15, image 2 of 3 HP Pavilion x360 m3-u001dx System Board Replacement: step 15, image 3 of 3
      • Remove the system board (motherboard).
      • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
      • Using the Phillips 00 Screw Driver, remove the silver screw.
      Ask FixBot
    5. HP Pavilion x360 m3-u001dx System Board Replacement: step 16, image 1 of 1
      • Carefully lift the front side of the system board (motherboard).
      Ask FixBot
    6. HP Pavilion x360 m3-u001dx System Board Replacement: step 17, image 1 of 1
      • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
      Ask FixBot
    7. HP Pavilion x360 m3-u001dx System Board Replacement: step 18, image 1 of 1
      • Release the system board (motherboard) from the base enclosure.
      • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
      Ask FixBot
Follow these instructions in reverse order to reassemble your device.
3 other people completed this guide.
_ thinhh@uw.edu
300 Reputation
2 Guides authored
UW Tacoma, Team 1-6, Rose Winter 2017 Member of UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 107
All Time: 4,737
