HP Pavilion x360 15t-br000 RAM Replacement
    1. HP Pavilion x360 15t-br000 RAM Replacement, Keyboard Panel: step 1, image 1 of 3 HP Pavilion x360 15t-br000 RAM Replacement, Keyboard Panel: step 1, image 2 of 3 HP Pavilion x360 15t-br000 RAM Replacement, Keyboard Panel: step 1, image 3 of 3
      • Remove the covers to access the screws attached to the back cover of the device.
      • Remove six 3mm screws using the Phillips #0 screwdriver.
      Ask FixBot
    2. HP Pavilion x360 15t-br000 RAM Replacement: step 2, image 1 of 3 HP Pavilion x360 15t-br000 RAM Replacement: step 2, image 2 of 3 HP Pavilion x360 15t-br000 RAM Replacement: step 2, image 3 of 3
      • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
      • Disconnect the keyboard panel cables under the upper case.
      • Remove the keyboard panel from the device.
      Ask FixBot
    1. HP Pavilion x360 15t-br000 RAM Replacement, Battery: step 3, image 1 of 1
      • Disconnect the battery cable from the device.
      Ask FixBot
    2. HP Pavilion x360 15t-br000 RAM Replacement: step 4, image 1 of 2 HP Pavilion x360 15t-br000 RAM Replacement: step 4, image 2 of 2
      • Remove the seven Phillips #0 4.5 mm screws.
      • Remove the battery from the device.
      Ask FixBot
    1. HP Pavilion x360 15t-br000 RAM Replacement, Motherboard: step 5, image 1 of 2 HP Pavilion x360 15t-br000 RAM Replacement, Motherboard: step 5, image 2 of 2
      • Disconnect the five cable connections to the motherboard.
      Ask FixBot
    2. HP Pavilion x360 15t-br000 RAM Replacement: step 6, image 1 of 1
      • Unscrew the nine 3mm mounting screws on the motherboard using the Phillips #0 screwdriver.
      Ask FixBot
    3. HP Pavilion x360 15t-br000 RAM Replacement: step 7, image 1 of 2 HP Pavilion x360 15t-br000 RAM Replacement: step 7, image 2 of 2
      • Lift the motherboard carefully then remove the motherboard.
      Ask FixBot
    1. HP Pavilion x360 15t-br000 RAM Replacement, RAM: step 8, image 1 of 1
      • Turn over motherboard and remove the RAM carefully from motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 639
