HP Pavilion x360 14-dw RAM Replacement
    1. HP Pavilion x360 14-dw RAM Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
      • Fully shut down your laptop and unplug all cables.
      Ask FixBot
    1. HP Pavilion x360 14-dw RAM Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet are facing up.
      Ask FixBot
    2. HP Pavilion x360 14-dw RAM Replacement, Expose the back cover screws: step 3, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement, Expose the back cover screws: step 3, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement, Expose the back cover screws: step 3, image 3 of 3
      • The ends of the rubber feet cover four back cover screws.
      • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
      • Make sure both the foot and its adhesive peel up together, as they need to be lifted up as one piece.
      • Peel up the end of the foot with your fingers just until the hidden screw underneath is exposed—you don't need to fully remove the foot.
      Ask FixBot
    3. HP Pavilion x360 14-dw RAM Replacement: step 4, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement: step 4, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement: step 4, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Peel up the other ends of the feet to expose the three remaining screws.
      • During reassembly:
      • Press down firmly on the ends of the feet to secure them into their recesses.
      • If the foot adhesive doesn't remain tacky enough to readhere, you can use double-sided tape such as Tesa Tape.
      Ask FixBot
    4. HP Pavilion x360 14-dw RAM Replacement, Unfasten the back cover: step 5, image 1 of 2 HP Pavilion x360 14-dw RAM Replacement, Unfasten the back cover: step 5, image 2 of 2
      • Use a Phillips screwdriver to remove the five screws securing the back cover:
      • Four larger 6.7 mm-long black screws
      • One smaller 2.9 mm-long silver screw
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      Ask FixBot
    5. HP Pavilion x360 14-dw RAM Replacement, Release the clips: step 6, image 1 of 2 HP Pavilion x360 14-dw RAM Replacement, Release the clips: step 6, image 2 of 2
      • Tight plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
      • Insert the flat side of an opening pick into the seam between the top right corner of the back cover and the frame.
      • Pry up to release the clips securing the back cover.
      Ask FixBot
    6. HP Pavilion x360 14-dw RAM Replacement: step 7, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement: step 7, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement: step 7, image 3 of 3
      • Insert the flat end of a spudger into the gap you just created.
      • Slide the spudger down to the bottom right corner to release the clips on the right edge.
      Ask FixBot
    7. HP Pavilion x360 14-dw RAM Replacement: step 8, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement: step 8, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement: step 8, image 3 of 3
      • Insert the flat end of a spudger between the bottom right corner of the back cover and frame.
      • Slide the spudger to the bottom left corner to release the clips.
      Ask FixBot
    8. HP Pavilion x360 14-dw RAM Replacement: step 9, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement: step 9, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement: step 9, image 3 of 3
      • Insert the flat end of a spudger between the bottom left corner of the back cover and frame.
      • Slide the spudger up to the top left corner to release the clips on the left edge.
      Ask FixBot
    9. HP Pavilion x360 14-dw RAM Replacement: step 10, image 1 of 2 HP Pavilion x360 14-dw RAM Replacement: step 10, image 2 of 2
      • Insert the flat side of an opening pick into the seam between the top edge of the back cover and frame, just to the right of the left hinge.
      • Pry up to release the clips.
      Ask FixBot
    10. HP Pavilion x360 14-dw RAM Replacement: step 11, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement: step 11, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement: step 11, image 3 of 3
      • Slide the spudger towards the right hinge to release the remaining clips.
      Ask FixBot
    11. HP Pavilion x360 14-dw RAM Replacement, Remove the back cover: step 12, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement, Remove the back cover: step 12, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement, Remove the back cover: step 12, image 3 of 3
      • Remove the back cover.
      • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all the clips.
      Ask FixBot
    1. HP Pavilion x360 14-dw RAM Replacement, Unfasten the battery: step 13, image 1 of 2 HP Pavilion x360 14-dw RAM Replacement, Unfasten the battery: step 13, image 2 of 2
      • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
      • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
      • Use a Phillips screwdriver to remove the four 4.6 mm-long screws securing the battery.
      Ask FixBot
    2. HP Pavilion x360 14-dw RAM Replacement, Remove the battery: step 14, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement, Remove the battery: step 14, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement, Remove the battery: step 14, image 3 of 3
      Buy
      • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
      • Some models may have a strip of tape covering the battery connector. Use a pair of blunt tweezers or your fingers to peel it up and remove it before removing the battery.
      • Remove the battery.
      • During reassembly, slide the bottom battery tabs into their slots on the frame, use the alignment posts to position the battery, and press down on the socket to secure it.
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      Ask FixBot
    1. HP Pavilion x360 14-dw RAM Replacement, Remove the RAM shield: step 15, image 1 of 2 HP Pavilion x360 14-dw RAM Replacement, Remove the RAM shield: step 15, image 2 of 2
      • Use the flat end of a spudger to pry up around the edges of the metal shield covering the sticks of RAM.
      • Pry up evenly around the shield's perimeter to avoid damaging the clips securing it.
      Ask FixBot
    2. HP Pavilion x360 14-dw RAM Replacement: step 16, image 1 of 2 HP Pavilion x360 14-dw RAM Replacement: step 16, image 2 of 2
      • Remove the metal shield.
      • During reassembly, align the metal shield over its clips and press down around the perimeter to secure it.
      Ask FixBot
    3. HP Pavilion x360 14-dw RAM Replacement, Unlatch the RAM: step 17, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement, Unlatch the RAM: step 17, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement, Unlatch the RAM: step 17, image 3 of 3
      • Your laptop has two memory slots, each with a pair of metal arms that secure a stick of RAM.
      • Simultaneously push out the metal arms on each side of a stick of RAM until they disengage and the stick pops up at a slight angle.
      Ask FixBot
    4. HP Pavilion x360 14-dw RAM Replacement, Remove the RAM: step 18, image 1 of 3 HP Pavilion x360 14-dw RAM Replacement, Remove the RAM: step 18, image 2 of 3 HP Pavilion x360 14-dw RAM Replacement, Remove the RAM: step 18, image 3 of 3
      • Pull the stick of RAM out of its socket to remove it.
      • Repeat for a second stick of RAM.
      • To install a memory module, insert it into its socket at a slight downward angle, then push down firmly until both metal arms lock the RAM in place.
      Ask FixBot
2 other people completed this guide.
Spencer Day
199,826 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
77,712 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 77
Past 30 Days: 355
All Time: 7,500
