HP Pavilion x360 14-ba253cl Keyboard Replacement
    1. HP Pavilion x360 14-ba253cl Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Use the Jimmy to remove the footpads located at the bottom of the laptop.
      Ask FixBot
    2. HP Pavilion x360 14-ba253cl Keyboard Replacement: step 2, image 1 of 1
      • Remove three 4.0mm Phillips #0 screws from the top of the cover.
      • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
      • Remove one 4.mm Phillips #0 screw beneath the divot.
      Ask FixBot
    3. HP Pavilion x360 14-ba253cl Keyboard Replacement: step 3, image 1 of 1
      • Turn the computer onto its base, with the computer open and the keys facing upward.
      Ask FixBot
    4. HP Pavilion x360 14-ba253cl Keyboard Replacement: step 4, image 1 of 1
      • Use an opening pick to separate the keyboard from the base of the laptop.
      Ask FixBot
    5. HP Pavilion x360 14-ba253cl Keyboard Replacement: step 5, image 1 of 1
      • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
      • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
      • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
      • Remove the keyboard from the laptop.
      Ask FixBot
Kristen Gismondi
108,502 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
83,619 Guides authored
1 Guide Comment
Kristen, How is the keyboard mounted to the top panel?
Larry Levy - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 76
All Time: 8,817
